Daredevil Pilgrim
Posted: Sat Sep 08, 2012 8:06 am Post subject: QDI Superb 4X V2.0 BIOS update... |
Hello, i have this rather old motherboard QDI Superb 4X V2.0 (original BIOS 1.1 2003 i think)...i have been searching the Internet for a newer update that corrects a lot of problems and boosts performance, in vain...all i find is updates for motherboards with similar naming but not for the specific...if someone has this update or knows where to find it, please contact...Thanks in advance...  |
Karlsweldt Enlightened Master
Posted: Sun Sep 09, 2012 5:13 am Post subject: |
Welcome to Motherboards.org!
Look in the lower left corner of the first video screen, for a string of characters. This is the BIOS date, version and model ID.
Hit the 'pause' button as soon as you see it, and it should freeze. Otherwise, create an error such as 'no keyboard found' to freeze that first image so you can copy the string. Post that string here, and a positive ID should link to finding a BIOS revision easily.
But also try this site.. http://www.motherboard.cz/driver/qdi.htm _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36375 Location: Netherlands, Breda
Posted: Mon Sep 10, 2012 1:50 am Post subject: Re: QDI Superb 4X V2.0 BIOS update... |
| Daredevil wrote: | Hello, i have this rather old motherboard QDI Superb 4X V2.0 (original BIOS 1.1 2003 i think)...i have been searching the Internet for a newer update that corrects a lot of problems and boosts performance, in vain...all i find is updates for motherboards with similar naming but not for the specific...if someone has this update or knows where to find it, please contact...Thanks in advance...  |
What is the reported fix-all version and what is it supposed to cure? Got a description somewhere? I may have something in the archives but without any specifics it will take too much time. _________________ We hate rut, but we fear change.
Daredevil Pilgrim
Posted: Fri Sep 14, 2012 3:36 am Post subject: |
Hello, thanks for your replies...
unforunately i don't have a version number for the BIOS update. All i found is a reference to a forum post
http://www.qdigrp.com/qdisite/bbs_en...998&Forum_ID=2
that no longer exists...it says that multiplies 8 times the performance of the RAM...a possible version number would be 1.2b or something like that, which fixes IOQD issues (i found this on the Internet but this link is dead also)...
As for my BIOS string i copied it below from SiSoft Sandra...
SiSoftware Sandra
Mainboard
Manufacturer : Q7
Multi-Processor (MP) Support : No
Multi-Processing (MPS) Version : 1.40
Model : SiS-648
BIOS : 08/18/2003-SiS-648-6A7I0Q79C-00
Chipset : SiS 648/655
Performance Enhancing Tips
Warning 231 : IOQD is set too low. Performance will suffer.
I hope all these help..Thanks again..! |
Posted: Fri Sep 14, 2012 5:20 am Post subject: |
From a Google search on that BIOS string:
BIOS : 08/18/2003-SiS-648-6A7I0Q79C-00 Chipset : SiS 648/655
http://www.wimsbios.com/biosupdates/qdi.jsp _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
Posted: Fri Sep 14, 2012 6:19 am Post subject: |
1.2b would be 1.2 beta which is newer than your 1.1 version you have now. Ok, that's a start, I'll see what I can do... _________________ We hate rut, but we fear change.
Daredevil Pilgrim
Posted: Wed Sep 19, 2012 7:36 am Post subject: |
Sorry, but this link (and similar ones) point to services which you need to buy in order to update your computer drivers...there is no direct download link... |
Posted: Thu Sep 20, 2012 5:54 am Post subject: |
Here is another link I found..
http://www.motherboard.cz/mb/qdi/Superb4.htm
Yes, many sites that offer chipset drivers want to sell a product.. first.. then offer "free" downloads of what you really wanted!
And here is the direct link to SiS driver downloads.. free. http://w3.sis.com/download/ Just enter what OS type and other factors, you should get the needed drivers. The SiS 648/655 chipsets were used in several brands. Perhaps another brand's drivers would work, but may not be 100% compatible. _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
Posted: Thu Sep 20, 2012 6:38 am Post subject: |
1) I'll have to check my offline archive to see if I happen to backup the 1.2b version of his bios.
2) I have to see if anything can be improved in that beta version with the publicly available patch utilities
3) I'll have to make an upload to somewhere and have it tested by the original poster _________________ We hate rut, but we fear change.
Daredevil Pilgrim
Posted: Sun Oct 14, 2012 2:36 am Post subject: |
| evasive wrote: | 1) I'll have to check my offline archive to see if I happen to backup the 1.2b version of his bios.
3) I'll have to make an upload to somewhere and have it tested by the original poster |
OK, after a while i have found a file that i think that corresponds ... here
http://qdi.mercuryserver.de/bios/index.php
in the search you can type "Superb" and i chose to download the file:
"2004-08-21 S4X slow performance with short IOQD BetaBIOS s4x2v12b-fix ioqd.bin"
which i think that corresponds to my motherboard. I have flashed the BIOS with this file and i believe that my system is a lot quicker. However the computer is rebooting in random time intervals, i mean even when i am just surfing on the internet. I have backed up my initial BIOS using the flash utility ...
Are you able to check if this file needs improvement as it you say or can you tell which utilities to use in order to do so? Do you need me to upload the original BIOS ? For example, if the reason the system has become unstable is the IOQD (which is now 12), maybe we can turn it to 4 or 8 ?
Again thanks for your help... |
