Vegeta100 Pilgrim
Posted: Thu Sep 06, 2012 11:24 pm Post subject: Need help plz!! looking for a motherboard and memory |
i have an hp Model #: a6419fh : http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01390598&lang=en&cc=us&taskId=135&contentType=SupportFAQ&prodSeriesId=3677047&prodTypeId=12454
the only think i upgrade long ago so now it looks:
Operating System
MS Windows 7 Ultimate 32-bit SP1
CPU
Intel Pentium E2180 @ 2.00GHz
Conroe 65nm Technology
RAM
3.00 GB Dual-Channel DDR2 @ 332MHz (5-5-5-15)
Motherboard
ASUSTek Computer INC. Leonite2 (Socket 775)
Graphics
HP w2207 (1680x1050@59Hz)
512MB GeForce 8400GS (PNY)
Hard Drives
335GB Seagate ST3360320AS (RAID)
Optical Drives
TSSTcorp CDDVDW TS-H653N
Audio
Realtek High Definition Audio
i have sc2 and want to buy bf3 in the near future.
i want to buy Intel G630 CPU 2.70GHz Processor but what motherboard will work with this and also memory.
i am handicap so i dont alot of money so i looking for the best stuff at a low price maybe under 100 dollars each part. i dont want amd b/c i been reading that amd makes alot of noises and my dad Alzheimer's disease so i dont want any noises for him.
maybe looking for a montherboard that supports Intel G630 CPU and also intel i3 so later on i can upgrade it. any help will be appreciated. |
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36377 Location: Netherlands, Breda
Posted: Fri Sep 07, 2012 3:33 am Post subject: |
You will need to replace the memory as well and most likely the power supply too if you are going to add any half-decent graphics card in there. _________________ We hate rut, but we fear change.
Vegeta100 Pilgrim
Posted: Fri Sep 07, 2012 3:43 am Post subject: |
| evasive wrote: | | You will need to replace the memory as well and most likely the power supply too if you are going to add any half-decent graphics card in there. |
aww also power supply  |
Posted: Fri Sep 07, 2012 4:40 am Post subject: |
Yes. This is an OEM box in which they have limited the possible upgrade path to make as much money as possible. It is not in their interest to give you a decent upgrade path, they want you to buy a new system (from them).
Do you want the upgrade total to be below $100? Or below 3x $100?
If the latter we'll attempt to get you a CPU/board/memory/PSU combo of reasonable quality within your budget. _________________ We hate rut, but we fear change.
Vegeta100 Pilgrim
Posted: Fri Sep 07, 2012 1:14 pm Post subject: |
| below 3x $100? OR I CAN BUY EACH PIECE BY MONTHLY OR MAYBE EVEN Refurbished |
Vegeta100 Pilgrim
Posted: Fri Sep 07, 2012 1:22 pm Post subject: |
| evasive wrote: | Yes. This is an OEM box in which they have limited the possible upgrade path to make as much money as possible. It is not in their interest to give you a decent upgrade path, they want you to buy a new system (from them).
If the latter we'll attempt to get you a CPU/board/memory/PSU combo of reasonable quality within your budget. |
i dont think i can upgrade all 3 item 100 dollars or below b/c i think is impossible.
i was thinking of this special: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128554 free memory what u guys think?? |
