Karlsweldt Enlightened Master
Posted: Sun Sep 23, 2012 5:14 am Post subject: |
If under-clocking the old memory and you had problems, the guilt finger points to other factors. If the PSU was marginal in its power output regulation, then the CPU may not have had enough power to perform optimally.. and controllers can be affected.
With the modern design of the memory controller on the CPU die, lower voltages are required.. and unless modules are rated for that lower voltage, they can falter. One missed clock cycle with paging can result in mini-dumps. The OS constantly flushes memory and reloads.. could be several times in only a second or two. Those cycles are seldom noticed. It is when a major memory dump happens.. such as a Kernel or System dump.. that the dreaded BSOD rears its head.
Good to hear all is stable now. Hopefully, no more hair-pulling! _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
bdub Black Belt 3rd Degree
Joined: 19 Feb 2003 Posts: 3330 Location: Washington D.C.
Posted: Mon Dec 10, 2012 8:59 am Post subject: |
just as an update...
the old pcp&p psu that was a possible culprit in this issue turned out to not work all that well when paired back with the original motherboard and a pci 6200 graphics card. it worked for a short time, then the system wouldn't start up, giving constant beeps... looks like it did give up the ghost for good.
also the mushkin ddr3 essentials kit went back to mushkin, and they sent me two new sticks to replace the bad. i haven't tested them yet in any machine, but i trust mushkin did me right. _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
zalman cpns5x performa hs/fan
antec neo he 650r
kingston hyperx 3k ssd 120GB
seagate 500GB HDD 32M cache
seagate 750GB HDD 32M cache
hitachi 1TB HDD 32M cache
lg wh14ns40 bd burner
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36385 Location: Netherlands, Breda
Posted: Tue Dec 11, 2012 12:56 am Post subject: |
open up the old PSU and check for bad capacitors please, especially the output one covered by the wire loom on the secondary side. If this PSU has bad brand caps in it, people need to know out there before it takes out other hardware. _________________ We hate rut, but we fear change.
Posted: Mon Dec 24, 2012 7:27 am Post subject: |
that's a good idea, i'll see if i can get it open.
mushkin screwed me, and sent me a bad stick back in that rma i made to them. one stick works good, the other won't even boot a computer! bastards! _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
antec neo he 650r
