Roach412 Black Belt 2nd Degree
Joined: 09 Aug 2004 Posts: 2456 Location: Milwaukee - Wisconsin
Posted: Thu Jun 28, 2012 1:39 pm Post subject: |
yeah - both stars are wireless access points. due to the construction of the house/etc the signal gets down to about 30-40% in the basement, and down to 10-30% upstairs. there's no coverage in the garage besides in the absolute closest corner to the modem.
for whatever reason i just cannot get the stupid netgear to be recognized with the motorola.
i've got the motorola essentially in factory settings.
LAN IP: 192.168.0.1 / 255.255.255.0
DHCP on, range 192.168.0.3-255
netgear is hacked down.
LAN IP: 192.168.0.2 / 255.255.255.0
DHCP off
gateway 192.168.0.1
etc etc
-Roach _________________ Lian Li Lancool First Knight Series PC-K59W
EVGA GTX 560ti FPB
Crucial M4 128gb SATAIII SSD
Corsair Professional Series HX850 PSU |
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36384 Location: Netherlands, Breda
Posted: Thu Jun 28, 2012 11:26 pm Post subject: |
And connecting any other device to the LAN connection the Netgear is on? Does that work? Is it getting an address?
In the Netgear, can you disable the WAN port? I have a feeling it's still trying to use that as default outgoing port for everything. _________________ We hate rut, but we fear change.
Posted: Thu Jun 28, 2012 11:32 pm Post subject: |
DD-WRT not supported on your revision:
http://www.dd-wrt.com/wiki/index.php/Netgear_WNDR3700
That would make things easier... I'd set the Netgear back to defaults, make it dish out addresses on its own LAN side in the 192.168.1.x range and have the WAN port set to 192.168.0.2 so double NAT, yes. _________________ We hate rut, but we fear change.
bdub Black Belt 3rd Degree
Joined: 19 Feb 2003 Posts: 3329 Location: Washington D.C.
Posted: Fri Jun 29, 2012 3:01 am Post subject: |
something about the second router needs to be in "client mode" to work as you got it in the setup. been reading a little last night about it, but it looks like evasive beat me to it in the post above. _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
zalman cpns5x performa hs/fan
antec neo he 650r
kingston hyperx 3k ssd 120GB
seagate 500GB HDD 32M cache
seagate 750GB HDD 32M cache
hitachi 1TB HDD 32M cache
lg wh14ns40 bd burner
Posted: Tue Jul 17, 2012 9:32 am Post subject: |
so - to make a long story short, i replaced the cable i had running between the two and it's actually working. something with that wire doesn't like holding a connection between the routers (or it wasn't making good connections in the ports) but would work when directly plugged into my PC. really frustrating, to say the least.
however, now i get some really inconsistent response times through the 2nd router...traffic is pretty slow, and pings to the web(google) bounce from ~50ms to ~250ms up and down, losing packets randomly in there.
modem is set to 192.168.0.1 / 255.255.255.0
2nd router is set to 192.168.0.2 / 255.255.255.0, 192.168.0.1 as gateway
DCHP enabled only on modem - handing out 192.168.0.5 through .100
i've been trying to poke around in the router with different preferences/settings turning things on/off or disabling features - like DoS protections, QoS, etc, etc... nothing seems to really make a difference.
EVGA GTX 560ti FPB
Twisty Black Belt 1st Degree
Posted: Wed Jul 18, 2012 6:44 am Post subject: |
If you do some packet capturing (winpcap) or maybe some pathping then that may help you track down what is going on with your data.
Have you set 192.168.0.1 as DNS on 2nd router.
I don't know what features your netgear has but basically you want to turn off as much can, disable any firewalls, advanced routing etc.
I am thankful I have an old Linksys which makes this kind of thing a lot easier. _________________ - Webster -  |
Posted: Wed Jul 18, 2012 7:26 am Post subject: |
sweet...maybe i'll get to this tonight.
| Twisty wrote: |
I don't know what features your netgear has but basically you want to turn off as much can, disable any firewalls, advanced routing etc. |
yeah, 192.168.0.1 is 2nd routers' DNS.
i'm not as familiar with netgear either. this is actually the first router i've ever had of theirs. i'll probably continue to browse little by little through documentation on it. hopefully find something useful.
EVGA GTX 560ti FPB
