Roach412 Black Belt 2nd Degree
Joined: 09 Aug 2004 Posts: 2456 Location: Milwaukee - Wisconsin
Posted: Sun Jun 24, 2012 9:00 pm Post subject: adding second router to cable modem/wifi router |
i got my cable service set up, and they gave me a Motorola SBG6580, which is a modem and wifi router all-in-one kind of deal.
i've set up my "lair" in my new house on the opposite side of the house that i have the modem/router - and i'm just lazy enough that i don't want to move it. rather, i have a Netgear N600 WNDR3700v3 wireless router that i want to add into the existing network that the Motorola is providing. problem is, i can't seem to get it to work.
did some of the obvious:
turned off DHCP in the Netgear, changed the SSID to be the same across both and applied identical credentials.
the netgear is hard-wired into the motorola, both into just LAN ports (not WAN). WAN on the netgear is unused currently.
i can get into the "second" network wirelessly. i can't seem to get an IP through the netgear from the motorola however. i'm foreced to manually set my IP when i connect to the netgear, but was expecting to get that info from the DHCP on the motorola...
i figure it's worth a shot to ask here, although i doubt anyone has the same setup as i do...
-Roach _________________ Lian Li Lancool First Knight Series PC-K59W
EVGA GTX 560ti FPB
Crucial M4 128gb SATAIII SSD
Corsair Professional Series HX850 PSU |
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36377 Location: Netherlands, Breda
Posted: Mon Jun 25, 2012 12:14 am Post subject: |
Set the Netgear to do DHCP, in the same subnet as the Motorola does, just a different range. If the Motorola dishes out .51 to .100 let the Netgear dish out .101 to .150 _________________ We hate rut, but we fear change.
Posted: Tue Jun 26, 2012 10:53 am Post subject: |
doesn't seem to work. the netgear can't seem to get to the motorola.
i can log onto either one and toodle around - but the motorola doesn't show the netgear attached, and the netgear can't get to the internet.
i don't want to bridge the motorola, because i want two access points for the same SSID - and have the ability to wire into the netgear in my other room. _________________ Lian Li Lancool First Knight Series PC-K59W
EVGA GTX 560ti FPB
Posted: Wed Jun 27, 2012 12:08 am Post subject: |
Is the Netgear a WAN router? If so, why not use the WAN port to go to the motorola and bridge the Netgear? _________________ We hate rut, but we fear change.
Posted: Wed Jun 27, 2012 7:06 am Post subject: |
wouldn't that double-NAT, unless i turned the motorola into a bridge, which would remove it as a wireless AP...?
everything i'm seeing says never wire an existing router (or modem/router) into the WAN of another router. that is with the exception of disabling the first router as a consumer of connections (i.e. bridging).
if i bridged the netgear, it wouldn't be a wireless AP, and i could only plug-in if i'm not mistaken.
EVGA GTX 560ti FPB
bdub Black Belt 3rd Degree
Joined: 19 Feb 2003 Posts: 3328 Location: Washington D.C.
Posted: Wed Jun 27, 2012 8:26 am Post subject: |
can i ask what the usefulness is of having two wireless routers in the same area? what do you hope to achieve?
you see the motorola from the "lair" to where it sits?
you are attaching a cable between the two routers? so they must be somewhat close to each other...
what's the point? _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
zalman cpns5x performa hs/fan
antec neo he 650r
kingston hyperx 3k ssd 120GB
seagate 500GB HDD 32M cache
seagate 750GB HDD 32M cache
hitachi 1TB HDD 32M cache
lg wh14ns40 bd burner
Posted: Wed Jun 27, 2012 9:14 am Post subject: |
cable modem is in one corner of the house, which allows good coverage for the wifi for about half the house. my computer room is on the other end of the house, through a few finished rooms, so the signal isn't good, it's poor to fair at best. i'd like to have a second wireless access point within that room (under the other half of the house) to improve my wireless signal, and advance it enough towards the front of the house to allow coverage into the garage (which the current setup doesn't allow).
i don't have a place to move the modem in the middle of the house in the basement with easy access to power, so i'd either need a stupid-long extension through the ceiling (which is illegal), juntion an existing line and create a new outlet, or "proudly" display my modem in the open (which i hate).
also, on the other side of the wall of my room is my home theater, which i don't have wireless components for. rather than running additional wired runs through the entire house to the other side i can plug those (as well as any guest computers lacking wifi) into the router in my computer room.
in short, it's for two reasons:
1) makes future setup simple
2) because i should be able to and it's interesting
EVGA GTX 560ti FPB
Posted: Thu Jun 28, 2012 9:28 am Post subject: |
so you DO want the two routers to talk to each other wirelessly. the second router being able to plug into and route components to the first one over the air. now i got it.
i thought you had them wired together, thus the talk about the wan port.
it's a good project. i'm curious to see it work. _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
antec neo he 650r
Posted: Thu Jun 28, 2012 11:52 am Post subject: |
not wireless, as that would require me to downstep my security to WEP.
modem/router is hard-wired (via LAN port) to LAN port on wireless router.
modem is big red star at the bottom, wireless router is smaller star at upper left.
orange thing is entertainment components.
top left is my room, and the adjacent(albeit ground-level) garage area signified in black.
CAT6 cable run is signified in green line
EVGA GTX 560ti FPB
Posted: Thu Jun 28, 2012 1:19 pm Post subject: |
essentially the upper two devices could be simple switches, but you want the red star devices both to be able to be used wirelessly.
i assume anything attached to the netgear using a wire is getting dhcp from the motorola down at the bottom with no issues...
have you looked for a firmware update for the netgear that might solve your issue?
nice diagram btw. _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
antec neo he 650r
