windows 7 but no cd
Post new topic   This topic is locked: you cannot edit posts or make replies.    The Mother Board Forum Index -> Operating Systems
jacobd23
PostPosted: Mon May 14, 2012 8:07 am    Post subject: windows 7 but no cd Reply with quote
hey guys, I was wondering if I can install windows 7 as a torrent into my new built pc. I have it installed onto a external hard drive but not a cd, would that work? also I apologize if we're not allowed to talk about torrents on the site.
thank you[/code]
bdub
PostPosted: Mon May 14, 2012 8:43 am    Post subject: Reply with quote
i am fairly certain the media has to be on a bootable device... and that the computer must be able to find the software to run. if you can set up an external hdd or a flash drive to do that, then yes. but if the file is just an iso or image of a disc, then i doubt you'll be able to initialize the install to start.
my main rig...
asrock 970 extreme3
AMD athlonII X3 440
zalman cpns5x performa hs/fan
antec neo he 650r
kingston hyperx 3k ssd 120GB
seagate 500GB HDD 32M cache
seagate 750GB HDD 32M cache
hitachi 1TB HDD 32M cache
lg wh14ns40 bd burner
PostPosted: Tue May 15, 2012 12:05 am    Post subject: Reply with quote
If you got the license somewhere that would be the same place to get the software from. On DVD, windows7 doesn't fit on a CD...
PostPosted: Tue May 15, 2012 7:40 am    Post subject: Reply with quote
Recent versions of Windows OS have an embedded (encrypted) list of COA license codes.. which the 'user' will not be able to find. For each run or stamping of the individual OS disks, a list of probable COA license codes are included. If the "match" of included license codes does not mate to the input of a COA, the installation will abort!
The only way to obtain an authentic issue of an OS install is when it includes that COA tag with the license number. The above information refers to individual sales of an OS install package. For businesses or large corporations, a package may include only two or three install disks.. plus a page (or two) of COA license numbers for install. Up to 100 individual installs can be made from the same stamping run. After that, the master pressing disks are destroyed. And any unsold license codes.
No, you cannot duplicate or "burn" a copy of the install disk. Certain hidden files will not copy over. But you could still make a backup copy for reference or daily use, excluding those certain files.
As evasive noted, the software and license are a dedicated pair.
jacobd23
PostPosted: Wed May 16, 2012 1:18 pm    Post subject: Reply with quote
i think the easiest thing would be to put my old windows on the new computer and then just download windows 7 run it through winrar. I did that with the computer i have now and it worked.
fussnfeathers
PostPosted: Sun May 20, 2012 9:06 am    Post subject: Reply with quote
No talking about torrents here, please. If you have a valid licence, you can burn the image to DVD. Otherwise, consider this topic closed.
Mine go to 11
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger MSN Messenger
Post new topic   This topic is locked: you cannot edit posts or make replies.    The Mother Board Forum Index -> Operating Systems All times are GMT - 8 Hours
Page 1 of 1
