Water cooling case suggestions
Postby Juggalo23451 » Thu May 10, 2012 7:32 am
CASE LABS
MH10 -holds 360 rads
TH10 4 480 rads put 6 480 rad in if you want to
STH10 -480 rads
Cooler Master Cases
HAF932- 360 rad top
HAFX- 360 rad top
ATCS 840- 360 rad top rad on the HDD cages
COSMOS II- 360 rad top, or 480 top modification required. 240 rad bottom
CM690- 240 rad with modification
Storm Scout -360 rad with modification
Cosmos S- 360 rad top
SILVERSTONE
TJ07- 480 rad and 240 rad bottom
TJ11
LIAN LI
PC-P80-360 rad
Tyr PC-X2000F- 360 rad front
PC-A77(B)-240 rads modification
Lian-Li PC-V2120-360 rad on top and 280 in the front
NZXT
switch 810
Tempest EVO-240 rad thin
CORSAIR
800D-360 rad top, 240 rad bottom with modification
700D- 360 rad top, 240 bottom with modification
Monitor 2343 samsung x3= 6144x1152
loop 1
res/mcp35x-rx480-gpu-gpu-rx480 white tubing
loop 2
res/mcp35x-rx480cpu-chipset-res
Juggalo23451
Postby Juggalo23451 » Thu May 10, 2012 7:33 am
DangerDen
Waterbox -240 rads
Tower 29- 480 rad
LDR Tower 29 Double wide-480 rads
loop 1
loop 2
Juggalo23451
Users browsing this forum: Exabot [Bot] and 0 guests
