Uploading Profile Avatar Error
Postby speckyteckie » Mon May 07, 2012 3:37 pm
Warning: move_uploaded_file(./images/avatars/10999521554fa85bad13c82.gif) [function.move-uploaded-file]: failed to open stream: Permission denied in /var/www/virtual/motherboards.org/htdocs/forums/includes/usercp_avatar.php on line 288
Warning: move_uploaded_file() [function.move-uploaded-file]: Unable to move '/var/www/virtual/motherboards.org/phptmp/phpiHiW6v' to './images/avatars/10999521554fa85bad13c82.gif' in /var/www/virtual/motherboards.org/htdocs/forums/includes/usercp_avatar.php on line 288
Warning: Cannot modify header information - headers already sent by (output started at /var/www/virtual/motherboards.org/htdocs/forums/includes/usercp_avatar.php:288) in /var/www/virtual/motherboards.org/htdocs/forums/includes/page_header.php on line 479
Warning: Cannot modify header information - headers already sent by (output started at /var/www/virtual/motherboards.org/htdocs/forums/includes/usercp_avatar.php:288) in /var/www/virtual/motherboards.org/htdocs/forums/includes/page_header.php on line 481
Warning: Cannot modify header information - headers already sent by (output started at /var/www/virtual/motherboards.org/htdocs/forums/includes/usercp_avatar.php:288) in /var/www/virtual/motherboards.org/htdocs/forums/includes/page_header.php on line 482
Was there an upgrade recently to the phpbb forum?
I would definitely recommend editing the above files, maybe check for blank spaces, code errors or just plain old permission errors with the upload directory.
speckyteckie
Users browsing this forum: DotBot [Bot] and 0 guests
