DidoTDI Pilgrim
Posted: Mon Apr 16, 2012 12:13 am Post subject: Unlock cores on AMD Phenom II X2 560 BE |
| I want to unlock my Phenom with GA-M52LT-D3. Should i update my BIOS first or i can unlock the cores without doing that? And can i unlock it with this motherboard at all? |
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36410 Location: Netherlands, Breda
Posted: Mon Apr 16, 2012 1:47 am Post subject: |
| Quote: | Core Boost Support
GIGABYTE’s Core Boost technology provides an easy way for users unlocking the CPU’s hidden cores via the EasyTune6 utility. Without any complicated setting needed in BIOS, users can experience a phenomenal performance upgrade right away.
*The ability of unlocking the hidden CPU cores might vary by different processors.
From the product page.
http://www.gigabyte.com/products/product-page.aspx?pid=3511#
Make sure you have a decent cooler in there as unlocking all 4 cores effectively makes this a 125W TDP processor. The stock cooler delivered with the CPU (if bought boxed) is not sufficient. _________________ We hate rut, but we fear change.
DidoTDI Pilgrim
Posted: Mon Apr 16, 2012 5:30 am Post subject: |
| I have Freezer 13 cooler. Can I unlock the cores with core boost, because I read I have to flash the BIOS.Is that true? And is that Mhotherboard support 125W. |
Posted: Mon Apr 16, 2012 6:02 am Post subject: |
For the Phenom X2 560 to work you need the F3B bios anyway.
I have been reading a bit more and I now see it depends on the processor stepping being a C2 or C3 as well.
It will take 140W (c2) or 125W (c3). Also seeing that not all 125W CPUs are supported, I think this is going to be tricky at best. I would advise you to use a different motherboard or a supported X4 Phenom such as the 960 _________________ We hate rut, but we fear change.
DidoTDI Pilgrim
Posted: Mon Apr 16, 2012 11:06 am Post subject: |
| Ok what motherboard I should use (no more than 100$)? And how i can see the stepping C2 or C3? |
fussnfeathers Mobo-fu Master
Joined: 04 Dec 2008 Posts: 3096 Location: Right behind you
Posted: Sun Apr 22, 2012 2:05 pm Post subject: |
CPUid will show you everything about your processsor. Also known as CPU-Z. _________________ Faster than the speed of snot |
DidoTDI Pilgrim
Posted: Tue Apr 24, 2012 2:21 am Post subject: |
| CPU-Z shows maximum TDP 71W. The stepping is C3. |
Posted: Tue Apr 24, 2012 3:56 am Post subject: |
OK, so at least the board will power it decently. That 71W TDP is with 2 cores active.
You need bios F3B for supporting your 560 in the first place and that is the last bios they released for this board.
The Freezer 13 is designed for 200W cooling, more than adequate for your unlocked 560.
Try unlocking one core at a time so first to 3 then to 4. With 3 cores active notice the TDP again, if you are already >105W, you may not be able to unlock core 4... _________________ We hate rut, but we fear change.
DidoTDI Pilgrim
Posted: Tue Apr 24, 2012 10:04 am Post subject: |
| Ok. Can you tell me the most save way to update the BIOS, because I don't want to screw it up. |
Posted: Wed Apr 25, 2012 12:21 am Post subject: |
From these I would prefer the DOS-based method because that is the oldest truely tried and tested way of updating.
http://www.gigabyte.com/webpage/20/HowToReflashBIOS.html
Question: do you have a known working floppy diskdrive and a known working floppy diskette? _________________ We hate rut, but we fear change.
