cccc Initiate
Posted: Fri Apr 13, 2012 3:43 pm Post subject: update BIOS automatically |
Hi
Normaly if I do a bios update, I must start the computer with a boot floppy and then choose bios update exe file manually.
Howto create a boot floppy to do BIOS update automatically, without asking anything? |
Karlsweldt Enlightened Master
Posted: Sat Apr 14, 2012 6:34 am Post subject: |
The process would need a 'batch' file to do the automated process. But you would still need to input certain data. Check www.bootdisk.com/ for needed files to create a proper boot disk, and the 'batch' file.
One caution: The floppy must be formatted in FAT12 style, the basic form that the BIOS program can access directly. This link may be of help.
When formatting the disk, do so only in the command prompt box of Windows or DOS 6.22.. or the format base will not be proper.
Formatting arguments for disks: _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
