..::L A N B O Y - A P O C A L Y P S E::..
Post new topic   Reply to topic    The Mother Board Forum Index -> Modding Work logs
Mnpctech.com
PostPosted: Thu Apr 12, 2012 3:40 am    Post subject: ..::L A N B O Y - A P O C A L Y P S E::.. Reply with quote
This log highlights photos from the PC project video I'm doing with "Mod Brothers Podcast" Host, Kyle Van Der Mewre (aka Kylevdm). ..."I don't care what we do, as long as we mod something" Kyle told me before arriving in Minneapolis. I recalled the disdain we shared for Antec's LANBOY Air when it was released. I proceeded to uncover the dusty sample I reviewed for Episode #5 of "Mod Men" ....One day before Kyle's arrival I stripped down the LANBOY and implemented ideas that Kyle could contribute during his 2.5 day visit. The only elements that remained of the LANBOY Air was it's frame and 2 side panels.
PC Designer, Engineer, & Modder "Cheapskate" contacted me 2 weeks prior to Kyle's visit with photos of a Stainless Steel Reservoir he was developing. The design looked very industrial, like a vacuum chamber. It ignited my imagination of a sci-fi theme for our project. Let's transform it into something that resembles a make shift portable Nuclear Fusion Generator in a Post-Apocalyptic landscape. Created from parts salvaged by an Engineer after a fictional WWIV. As we worked, the fictional story started to take life... "He worked as a Senior Engineer at Los Alamos National Laboratory in their Developmental Dept before it was demolished in 2010." ...... From this point on, the build took on it's own life...
Unimpressed by Antec's Lanboy Air from Episode #5 of "Mod Men"
The factory finish was sanded and scuffed up, before it was permanently turned upside down with the PSU relocated to the outside.
[URL="http://www.mnpctech.com/casemodblog/2011/06/13/case-mod-guide-mnpctech-cable-management-routing-grommets/"]Cable Management grommets[/URL] were added to the ceiling.
The side panels are suspended like Gull Wing doors with "Laurey" style Cabinet Hinges from WoodCraft, http://www.woodcraft.com/Product/2021219/25993/Laurey-Hinge-Oil-Rubbed-Bronze-No-Inset-Surface-Mount-Pair.aspx
250mm cooling fan shroud I fabricated for the radiator from the SWORDM sent by Thermaltake for AMD build in 2006.
The front intake grill is a combination of machined aluminum 120mm "Reactor" fan grill and 120mm Blow Hole kit.
page link, http://www.mnpctech.com/blowholefan.html
120mm Enermax VEGAS DUO in Blue/Red combo-LED with 11 switchable LED color modes.
Factory Product Page Link, http://www.enermax.com/home.php?fn=eng/product_a1_1_1&lv0=4&lv1=39&no=128
This is the front of the Lanboy chassis with 20 gauge sheet metal I fastened on, for the intake fan.
The SWORDM radiator measures 8" x 9.25" wide with 3/8" barbs. The chassis was painted Charcoal Grey Metallic and Flat Black
I fabricated a new bezel to accommodate the Stainless Reservoir. I combined the top panels from a Lancool K58 Dragon and Fractal-Design Arc Midi. The 5.25" Toggle switch plate is thick machined aluminum.
The front intake is a combination of the 120mm "Reactor" aluminum fan grill and 120mm Blow Hole kit.
After painting the bezel Charcoal Grey Metallic, I added Round version of Modders Mesh to the openings in the sides.
250mm is installed on the radiator. Fitting the new bezel and it's fastener screws. This will be painted Charcoal Grey Metallic, to match the chassis.
Road Warrior action figure discovered while touring [URL="http://www.peacockgroove.com/"]Peacock Groove[/URL] workshop in my warehouse on Thursday night. It won't be implemented in the project, but reminded of us of a grungy "Post-Apocalyptic" atmosphere from the movie, and inspired an idea or two for the build on following day.
Kyle is implementing UV Green Transparent acrylic windows...
Flipped MB tray with EVGA X58 and i7 920, cooled by XSPC Raystorm Waterblock
Mnpctech.com
PostPosted: Fri Apr 13, 2012 7:11 am    Post subject: Reply with quote
Thank you for sharing your question! They don't, but wish they did for that reason....
The Stainless Steel Reservoir made by Cheapskate with Transparent Purple acrylic caps and clear acrylic clamps.
Determining the Res location over the Mnpctech blowhole ring on the front of the PC......
I fabricated the Bezel from Fractal-Design Arc Midi and Lancool Dragon K58 top panels
The custom bezel was given distressed and weathered paint effect.
The bezel is painted with Charcoal Grey Metallic paint, then highlighted with Flat Black paint.
Areas of the painted are scuffed with red Scotch-brite pad to create weathered effect.
The Core i7 920 is cooled by the XSPC Raystorm Waterblock.
Mnpctech.com
PostPosted: Sun Apr 15, 2012 2:15 am    Post subject: Reply with quote
We gave the ASUS GTX 560 Ti's factory fans and shroud a "Steampunk" makeover.
Kyle made the Copper rings while I modified the factory shroud.
Kyle airbrushing aged and weathered effect on the "steampunk" inspired shroud.
Mnpctech.com
PostPosted: Tue Apr 17, 2012 6:29 am    Post subject: Reply with quote
Thank you everyone for tuning into this project log. Over Kyle's 2 day visit, we transformed Antec's Lanboy Air into our vision of something that resembles make shift portable Nuclear Fusion Generator in Post-Apocalyptic landscape..
Our Lanboy mod makes no apologies for being Mean & Nasty looking.
The Gullwing style side panels were created with spring loaded hinges. The Lanboy was painted "Charcoal Grey" metallic with "distressed and weathered" highlights.
The XSPC Raystorm waterblock is kept cool with the massive 250mm cooling fan mounted on 8" x 9.25" wide Thermaltake radiator that was taken from their "SwordM" full tower. The fan behind the Stainless Steel reservoir is Enermax VEGAS Trio in Blue/Red/Green combo-LED with 11 switchable LED color modes.
Kyle created a custom switch box for the top with plastic wire loom covering the wires. The Green faucets created the illusion of plumbing for the toxic waste. The Lanboy chassis was flipped upside down with the NZXT 850 PSU relocated to the exterior. The watercool loop exits and re-enters the interior through in the top of the PC.
Intel Core i7 970, EVGA X-58 Classified, 12 GB Corsair DDR3, Dominator-GT, XSPC Raystorm CPU waterblock, Asus ASUS GTX 560, NZXT 850 Watt PSU, Mushkin 120 GB Calisto SSD
Mnpctech.com
PostPosted: Tue Apr 24, 2012 10:07 am    Post subject: Reply with quote
Ok, here is system photos as promised. It's been upgraded to Intel Core i7 970. The i7 is cooled with XSPC Raystorm CPU waterblock. The motherboard is EVGA's X-58 Classified with 12 GB of Corsair's DDR3 Dominator-GT and ASUS GTX 560 DirectCUII. Powered by NZXT's 850 Watt PSU with Win7 on Mushkin's 120 GB "Callisto" SSD.
Mnpctech.com
PostPosted: Sat Apr 28, 2012 12:25 pm    Post subject: Reply with quote
Uploaded video with highlights from this build and random fun we had during kyle's visit from Scotland big grin
http://youtu.be/CUKyMs7Mgio
Mnpctech.com
PostPosted: Wed May 02, 2012 1:33 pm    Post subject: Reply with quote
Kyle and I were pleased to discover KOTAKU shared our "Apocalypse PC" in their News. It's awesome to see a PC Mod featured on this popular blog
http://kotaku.com/5907097/a-nuclear-pc-mod-for-a-post+apocalyptic-world
Post new topic   Reply to topic    The Mother Board Forum Index -> Modding Work logs All times are GMT - 8 Hours
Page 1 of 1
