cccc Initiate
Posted: Fri Apr 06, 2012 5:29 am Post subject: BIOS updates from an OS directly? |
hi
Is not quite dangerous, that we can today do BIOS updates from an OS directly?
Is this not nutrient for some viruses? |
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36384 Location: Netherlands, Breda
Posted: Fri Apr 06, 2012 5:43 am Post subject: |
If you are getting your update from any other source than the board manufacturer this is a risk. the same holds true for any software not coming from the original source.
As with regular (ie DOS flashing) the same holds true: do this on a system that is as clean as possible so very early in the install process. Personally, I know things have gotten better, the high casualty rate on online bios updates is because most people will do one on an already unstable system hoping it will fix the errors/slowness they caused in the first place by installing loads of software...
Am I sounding bitter? _________________ We hate rut, but we fear change.
cccc Initiate
Posted: Fri Apr 06, 2012 7:33 am Post subject: |
| evasive wrote: | If you are getting your update from any other source than the board manufacturer this is a risk. the same holds true for any software not coming from the original source.
Am I sounding bitter? |
No, I mean if the virus can find out bios model/version by itself and change/overwrite/destroy it, without the user knows about. |
Karlsweldt Enlightened Master
Posted: Fri Apr 06, 2012 8:57 am Post subject: |
I do not consider the process of flashing or updating a BIOS file when the OS is active a 100% secure route. Too many processes are active during this critical step, and a good chance something can go awry. And you cannot just update or renew the BIOS files and continue operating! The system must be shut down and reset, then restarted, for the 'new' BIOS program to be effective. The only surest, safest means of a BIOS update or change is via a floppy disk or a USB flash stick while the BIOS is in its own entity.
Yes, many newer BIOS versions have a "backup" memory in case the program becomes corrupt during the update process. Saving grace for not getting a useless mobo after a bad flash! _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
Posted: Sun Apr 08, 2012 1:42 am Post subject: |
| cccc wrote: |
Interesting point of view. However, by building something like that you are targeting a very small audience for each variant, it's complicated, big (you need to have bios images for each model) and not very practical. These days viruses are written for profit mainly. _________________ We hate rut, but we fear change.
