New Gaming Build. New feedback plz
Post new topic   Reply to topic    The Mother Board Forum Index -> Recommendations
thirdeye00
PostPosted: Fri Mar 23, 2012 11:45 am    Post subject: New Gaming Build. New feedback plz Reply with quote
Budget Range: under 2,000 [1500ish]
System Usage: Gaming. Mostly playing SWTOR...highest setting possiable
Parts Not Required: keyboard, mouse, monitor, speakers, OS
Overclocking: Yes
SLI or Crossfire: Maybe in the future, havent really used this option. any ideas?
Monitor Resolution: Will be using two19in monitors at the moment. Might upgrade one to like a 22in and still use the other 19in if possible
Additional Comments: Like to this built to be upgradeable and be able to last
CPU: Intel Core i5-2500K $219
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
CPU Cooler: COOLER MASTER Hyper 212 $29
MoBo: Not for sure about motherboards..Need help here.. $129
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271
or?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157269
PSU: CORSAIR 850W Should be enough with OCing? $189
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
Harddrive: Seagate 2TB $119 Might downgrade to 1TB or 500GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148681
SSD: Crucial 128gb big enough? $164
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148448
Ram: 8gb $50 any tips
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145345
GPU: Im still up in the air for GPU...GTX 680
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130768
Case:Rosewill $90 open for ideas... like cable management, fans
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147107
This system is basically for playing SWTOR for now. But want to leave my opinions open for other uses i might need for it. Also would like to make this a system to last and able to upgrade. Thanks ahead for any feedback
amadnei
PostPosted: Sun Mar 25, 2012 1:00 pm    Post subject: Reply with quote
I would suggest a better cpu cooler, cooler master are not making the best cpu cooler ( overall ofc ) and I would suggest a gigabyte or asus mobo
after you dont need a 680 gtx to play mmo (overall) you can max it at really less than that , even a 560 non ti would be able
Roach412
PostPosted: Mon Mar 26, 2012 7:40 am    Post subject: Reply with quote
nothing wrong with that cooler. i have the "212 plus" in my system and it's awesome. never seen the temps go over 42c on my i7.
-Roach
EVGA GTX 560ti FPB
Crucial M4 128gb SATAIII SSD
View user's profile Send private message Send e-mail AIM Address
Post new topic   Reply to topic    The Mother Board Forum Index -> Recommendations All times are GMT - 8 Hours
Page 1 of 1
