zooofer Green Belt
Joined: 08 May 2006 Posts: 103 Location: southeast usa
Posted: Sun Mar 18, 2012 5:58 pm Post subject: Ubuntu internet connection. |
Greetings all. I have been running Ubuntu on a couple different machines. One Gateway laptop, its about five years old, dual core AMD turion with a gig of ram. The other machine, I don't know much about, its a small pc I found at work. Really low level performance. The problem that I am having is when I first installed the os, it accepted its address from the DHCP server and my internet connection was fine. Then out of the blue, my internet connection just stops working. So I checked the settings and everything seemed to be right. I assigned a static I.P. and still no luck. This happened to both machines and that really bothers me. The O.S. was not updated. I think it was version 10.
Thanks everybody. |
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36381 Location: Netherlands, Breda
Posted: Mon Mar 19, 2012 12:28 am Post subject: |
OK, there's no brand name on the machines? No idea what kind of network card is in there? _________________ We hate rut, but we fear change.
zooofer Green Belt
Posted: Sat Mar 24, 2012 12:48 pm Post subject: |
| Thank you so much for your responce. I can't believe I'm going to say this, but my whole problem was I had a bad cable. I am sorry for wasting your time. |
fussnfeathers Mobo-fu Master
Posted: Sat Mar 24, 2012 1:36 pm Post subject: |
Thanks for the update....nothing is too silly to post. You might help someone else out!  _________________ Mine go to 11 |
