Can I Transfer My OS From One HHD To Another?
Goto page 1, 2  Next
Post new topic   Reply to topic    The Mother Board Forum Index -> Operating Systems
OneSpirit
PostPosted: Sat Feb 11, 2012 9:52 pm    Post subject: Can I Transfer My OS From One HHD To Another? Reply with quote
Hey all ... question ... If I were to purchase an SATA drive would I be able to transfer all the files to it including my OS on my IDE drive and would it still function properly on the new drive SATA drive? Thanks in advance. lachen
Gigabyte GA-M68MT-S2 mobo
AMD FX 8120 3.1 Ghz 4000MZ
8Gb DDR3 1333
Windows XPPro/Win7 Ultimate
Gigabyte GTX 280 GPU
WD100000 SATA 7200rpm
2 Sony(Optiarc) DVD AD-7280S
Inland ILG-600 P/S
Directx9
PostPosted: Sun Feb 12, 2012 4:38 am    Post subject: Reply with quote
Depends on the make of the harddisk, some have got transfer software that will allow you to migrate the whole bunch including adjusting your boot.ini file and support for the SATA controller. Is this for your D845GRG?
OneSpirit
PostPosted: Sun Feb 12, 2012 5:14 pm    Post subject: Reply with quote
I'm going to replace the D845GRG with a Gigabyte M68MT-S2 ... I'm planning to get the sata WD or Seagate 1tb drive and I have the WD IDE 500G drive.
Would I have to use some kind of cloning program to do it? If worst come to worst I will keep the IDE drive with the OS and transfer everything else to the SATA drive.
8Gb DDR3 1333
Inland ILG-600 P/S
Directx9
PostPosted: Sun Feb 12, 2012 9:31 pm    Post subject: Reply with quote
Won't work, the chipsets are too different.... You'll need to do a fresh install (you are far better off doing that anyway)...
OneSpirit
PostPosted: Mon Feb 13, 2012 9:10 am    Post subject: Problem with Fresh Install Reply with quote
The Problem with doing a fresh install is M$ Flight Simulator X ... I only have so many times I can use the key, I like to avoid that. So I'd rather keep the IDE drive along with the SATA drive. I'll just use an adapter. I've got a lot of add on in FS 2004 and I really don't want to put it all back again ... Hopefully all will be well running the two drives.
8Gb DDR3 1333
Inland ILG-600 P/S
Directx9
bdub
PostPosted: Mon Feb 13, 2012 1:43 pm    Post subject: Reply with quote
you'll be lucky it gets to boot all the way into the OS, much less be able to fly bug-free.
there is tip sheet about transplanting system hdd's to other motherboards successfully. part of it is uninstalling as many drivers as you can.
maybe someone knows these tips, and has a link? i can't seem to locate it.
it doesn't assure success at all, though. you are traversing a very rocky road.
my main rig...
asrock 970 extreme3
AMD athlonII X3 440
zalman cpns5x performa hs/fan
antec neo he 650r
kingston hyperx 3k ssd 120GB
seagate 500GB HDD 32M cache
seagate 750GB HDD 32M cache
hitachi 1TB HDD 32M cache
lg wh14ns40 bd burner
PostPosted: Tue Feb 14, 2012 2:14 am    Post subject: Reply with quote
Most likely that will involve pre-installing the drivers for the new mass storage controllers when the disk is still in the old system, starting in safe mode in the new system after a repair install.
No matter how you think you are going to do it, the amount of junk staying behind in your registry and system folders will be legendary and can severely hinder the performance of the new system thus making the "upgrade" a bit of a farce.
OneSpirit
PostPosted: Tue Feb 14, 2012 12:17 pm    Post subject: Reply with quote
Well I guess I have to see how it goes once I get the parts. I'd hate to lose all my data and have to reinstall all my flight sims and all the addons that goes with them ... and FSX is like XP which may or may not allow me to use the same key.
8Gb DDR3 1333
Inland ILG-600 P/S
Directx9
bdub
PostPosted: Tue Feb 14, 2012 1:32 pm    Post subject: Reply with quote
sometimes you can take the program files folder that holds the game you want and copy it to an external drive, then after initial install of the program on your new OS disk, copy your original data to the new drive...
all the old data overwrites the new data, and you have your flight simulator working just as it ever did. this doesn't always work perfectly, but it is worth a shot.
as far as xp, you should be able to activate your new setup with a simple call-in to M$ if you can't activate the regular way.
the time you spend doing a clean install is worth it.
my main rig...
asrock 970 extreme3
AMD athlonII X3 440
antec neo he 650r
OneSpirit
PostPosted: Wed Feb 15, 2012 2:36 pm    Post subject: What about my IDE Hard drive? Reply with quote
Would there be a problem if I kept my IDE drive as the master and have the sata as a slave when I get one? confused
8Gb DDR3 1333
Inland ILG-600 P/S
Directx9
Post new topic   Reply to topic    The Mother Board Forum Index -> Operating Systems All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
