Tight Budget Upgrade
Goto page Previous  1, 2, 3, 4, 5
Post new topic   Reply to topic    The Mother Board Forum Index -> Recommendations
OneSpirit
PostPosted: Sat Mar 17, 2012 11:00 am    Post subject: Can't Be A Bug W/ HW Monitor Reply with quote
Well sir ... I installed HW Monitor on the system we have talked about in a different thread with the Bestec that has a bad rep ... this is the readings I get for the P/S
ATX +3.3V (Min:3.30v Max: 3.33v)
+5V (Min: 5.08 Max : 5.13v)
+12 (Min: 11.98 Max:12.24v)
So what does this mean? Could it be because that one P4 pins on the mobo is scorched be the reason? Or is it the P/S itself? What is your recommendation? PDT_Armataz_01_03
I highly doubt HW Monitor has a bug. Neutral
On second thought after looking at evasive's link again the +5 is in the 24 pin clip ... no information on whether or not it is in the P4 clip. According to the link ...
"Drive circuits and some motherboard circuitry uses 5V power. System RAM, USB devices and LCD panel displays use 5V. PCI cards use 5V and/or 3.3V. PCI cards use 5V and/or 3.3V."
So some of these components are not getting enough power?
confused
Gigabyte GA-M68MT-S2 mobo
AMD FX 8120 3.1 Ghz 4000MZ
8Gb DDR3 1333
Windows XPPro/Win7 Ultimate
Gigabyte GTX 280 GPU
WD100000 SATA 7200rpm
2 Sony(Optiarc) DVD AD-7280S
Inland ILG-600 P/S
Directx9
OneSpirit
PostPosted: Sat May 05, 2012 9:28 am    Post subject: Computer dead Reply with quote
Well sir ... the computer died on me yesterday ... I go to boot it up and no system beep ... the P/S fan is turning and I get some power, but no boot up. It's either the P/S or the mobo ... I thought the one P/S had the pins for the video card, but it doesn't so I decided to order another P/S and see what happen since the P/S reading was low. So that's that. Will let you know what happens when I get the new P/S ...
8Gb DDR3 1333
Inland ILG-600 P/S
Directx9
OneSpirit
PostPosted: Wed May 09, 2012 8:01 am    Post subject: Reply with quote
Well sir ... got the P/S today and it works ... unfortunately I'm still getting that bad reading for the 5 volts ... looks like I will have to order a new mobo ... crying .... owned
8Gb DDR3 1333
Inland ILG-600 P/S
Directx9
OneSpirit
PostPosted: Wed May 16, 2012 10:04 am    Post subject: Reply with quote
Well sir ... I'm having problems ... going to start an new thread in the tech support section.
8Gb DDR3 1333
Inland ILG-600 P/S
Directx9
cordsally
PostPosted: Fri May 25, 2012 6:52 pm    Post subject: Reply with quote
Thanx for this information, i also had the same query,not exactly same but a little bit,found solution,thankyou once again callsign
Post new topic   Reply to topic    The Mother Board Forum Index -> Recommendations All times are GMT - 8 Hours
Page 5 of 5
