Juggalo23451 Initiate
Posted: Tue Oct 18, 2011 8:02 pm Post subject: Case Labs TH10, 4way classifed, gtx590s and water cooling |
Specs of build
Evga 4 way classified
Intel 970
2 gtx590s
Muskin ram 6-12gig
2tb wd caviar black
ssd 128 crucial c300
psu 1500 silverstone
Water cooling
primochill Orange 1/2x 3/4 tubing
enzotech compression fittings 1/2x3/4
2 MCP35X pump
XSPC dual bay res for two pumps
White HK
Koolance water blocks
Koolance sli adapter
2 RX 480 rads
1850 Gentle typhoons pull
ek 4 way classified water block
loop order will go
res-pump-rad-gpu-gpu-rad-cpu-chipset-res
Reason I have the chipset last is because it has the most restriction
http://www.youtube.com/watch?v=VDD164O3pHY
http://www.youtube.com/watch?v=r_ZsPCeFYPk
only temp still needs work
[COLOR="Red"]NEW LOOP[/COLOR]
http://www.youtube.com/watch?v=mfpeQ0cj79o
http://www.youtube.com/watch?v=g7smRFYGcbI _________________ Monitor 2343 samsung x3= 6144x1152
loop 1
res/mcp35x-rx480-gpu-gpu-rx480 white tubing
loop 2
res/mcp35x-rx480cpu-chipset-res
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36384 Location: Netherlands, Breda
Posted: Tue Oct 18, 2011 8:09 pm Post subject: |
Just one minor thing, if going through that much trouble to make a white/orange setup, use a bit of spray paint for the back of that DVD-player... (mask the connectors!) Other than that, nice setup  _________________ We hate rut, but we fear change.
Posted: Tue Oct 18, 2011 8:20 pm Post subject: |
| evasive wrote: | Just one minor thing, if going through that much trouble to make a white/orange setup, use a bit of spray paint for the back of that DVD-player... (mask the connectors!) Other than that, nice setup  |
I would but I cant spray paint in my apt. _________________ Monitor 2343 samsung x3= 6144x1152
loop 1
loop 2
res/mcp35x-rx480cpu-chipset-res |
Posted: Tue Oct 18, 2011 10:13 pm Post subject: |
...and you have no place near the building outside where you can use a cardboard box for a makeshift spray booth? hmmm, on second thought it is rather cold outside already... I'd say for future improvement then... next summer... _________________ We hate rut, but we fear change.
Posted: Wed Oct 19, 2011 4:28 am Post subject: |
| evasive wrote: | | ...and you have no place near the building outside where you can use a cardboard box for a makeshift spray booth? hmmm, on second thought it is rather cold outside already... I'd say for future improvement then... next summer... |
yes it getting cold here in Colorado. No painting is allowed at all. Ill ask one of the maintenance guys if I can use there shack to paint _________________ Monitor 2343 samsung x3= 6144x1152
loop 1
loop 2
