How's my temps
Post new topic   Reply to topic    The Mother Board Forum Index -> Overclockers Anonymous
Ol Dave
PostPosted: Mon Sep 26, 2011 7:44 pm    Post subject: How's my temps Reply with quote
Not sure this is the right forum, but thought I'd start here. I'm seeing 55c on air after gaming and I just want to make sure I'm not running too hot given that I haven't OC'd this thing yet. I used Artic Silver paste, but not extremely confident that applied enough or maybe too much. From what I read, it seems there's a fine line on this.
There is a lot of heat added to the room and I thinkg that's actually a good thing, but there's that 'something's hot' smell, so I'm concerned. Just want to prevent premature failure. I count 8 fans total.
Also, I plan to go 4ghz soon and need cooling solution sugestions please.
Thanks for your thoughts!!
CPU = AMD Phenom X4 970
MOTHERBOARD = Asus Crosshair Formula IV
RAM = 4 x 2gig Corsair
HEATSINK = Stock (artic silver)
OS = Win 7 64bit Pro
POWER SUPPLY = OCZ 1000w
VIDEO CARD = 2 x XFX 5870 in crossfire
SOUND CARD = M-Audio 5.1
2 x OCZ SSD in raid 0 for OS and 2 WD for storage
CASE = Thermaltake Saprano
aleaddict
PostPosted: Wed Oct 19, 2011 2:36 pm    Post subject: Reply with quote
I just built a new system using the AMD 1100T processor and have questioned my own temp readings while running Prime95 @ 4GHz. From everything I've read so far, you should have nothing to worry about. One question I would ask is are you reading your core temp or socket temp? I would recommend running Core Temp 1.0. My socket temps run between 52-55*C @ 4GHz during Prime95 with a core temp of around 45-46*C. I have also monitored my temps using Gigabyte TouchBIOS, AMD OverDrive and HWMonitor. Only Core Temp 1.0 (with a small screen footprint) and HWMonitor displays my actual core temps.
-- ale
MSI K8N Neo Platinum nF3 250Gb
A64 3200+ Clawhammer (CG)
1 Gb (2x512Mb) OCZ Platinum PC-3500
Koolance PC2-650 (CPU, chipset, vid & HDD's)
eVGA FX5900se
ANTEC 480W TrueBlue PSU
WD 74Gb SATA "Raptor"
WD 250Gb SATA
View user's profile Send private message Yahoo Messenger
Storm
PostPosted: Thu Jan 19, 2012 10:58 am    Post subject: Reply with quote
what program / command are you guys using to check temps? just curious. i am running windows 7, and i use a widget called core temp, but in order for the widget to work, the program has to be open (when you minimize it, it disapears) but still its annoying to have to open it. i guess i could just add that program to the startup folder, but if you have a better widget i'd like to know.
quite honestly i love the widget, i just dont like opening it the way they have it set up
it shows your current cpu speed for each individual core, each cores usage %, and each cores temp. as well as ram usage and some other things
Roach412
PostPosted: Thu Jan 19, 2012 12:11 pm    Post subject: Reply with quote
50's are totally fine. 60's are starting to get hot 70+ and you get into trouble.
i've had some cpus idle in the 30s, others in the 40s. under load though, i typically never see them get higher than mid-upper-50's.
-Roach
EVGA GTX 560ti FPB
Crucial M4 128gb SATAIII SSD
View user's profile Send private message Send e-mail AIM Address
Post new topic   Reply to topic    The Mother Board Forum Index -> Overclockers Anonymous All times are GMT - 8 Hours
Page 1 of 1
