Star Trek Case Mod: "TRICORDER CHIC"
Goto page 1, 2, 3  Next
Post new topic   Reply to topic    The Mother Board Forum Index -> Modding Work logs
Mnpctech.com
PostPosted: Thu Jun 02, 2011 9:29 am    Post subject: Star Trek Case Mod: "TRICORDER CHIC" Reply with quote
A Star Trek case mod theme that will be stylish.. Er, I mean Chic! and we've only got 12 days to get it finished!
Maximum PC has a presence at Comic-Con every year as an outreach opportunity—to let the hardcore comics and sci-fi fans know that PC enthusiasm goes hand-in-hand with that kind of fandom. This year we’re using our booth as an opportunity to show the fans at Comic-Con how awesome a great case-mod can be and how PC geekery and sci-fi enthusiasm can meet in a beautiful way. So we’ve hired the best guys in the business to design and build an awesome Star Trek-themed PC, and we’ll be giving one away at Comic-Con and the other one will go to David Gerrold in exchange for some writing he’s doing for us in relation to Comic-Con. - Nathan Edwards, Senior Associate Editor
[/CENTER]
[CENTER] Conceptual Designer: Mike Okuda is graphic designer who has worked on Star Trek series since the 1980s and is responsible for much of its visual style, including the LCARS interface as seen on Next Generation.
Matt Jefferie's original design of the Tricorder served as Mike's inspiration for styling cues on the "Tricorder Shiek" computer case
design. We could have scratch built a PC that looked just like the Tricorder, but David wanted an actual computer case instead with specific utilitarian features like hot swap bays and a compartment for his Tribbles.
3D design of "Tricorder Shiek" by Dave LaLopa
Top panel and storage compartment
Top panel will be milled from 2" thick 6061 aluminum
This Lancool K-58, manufactured by Lian Li will sacrifice it's chassis to this project.
Lancool K-58 chassis will be painted Matte Black Enamel.
Using Rounded side hand file to smooth the cut edges.
Using Red Scotch-Brite pad to scuff the surface in preparation for Primer base coat.
Lancool K58 chassis painted Matte Black Enamel (1 for david, 1 for comic-con)
Machined aluminum computer case feet, http://www.mnpctech.com/ITX_MATX_Computer_Case_Feet.html
Machined aluminum computer case feet with grooved edges.
The aluminum feet are machined on CNC Lathe, http://www.mnpctech.com/ITX_MATX_Computer_Case_Feet.html
The bare aluminum is nice contrast to the Matte Black.
#10 x 5/8" Black Oxide Fan Screws, http://www.mnpctech.com/thumbscrew.html
Screws will be used in conjunction with fan silencing rubber grommets, http://www.mnpctech.com/FanGrommet.html
#10 x 5/8" Black Oxide Fan Screw inserted in rubber grommet
Yate Loon Blue LED 140mm cooling fan (1 of 2)
Lian Li Tool-Less PCI Card Holder, 7 x PCI Holder. Works with many Lian Li cases or other modified cases. Specifications: Tool-Less PCI Card Holder, 7 x PCI Holder. Designed for Most of Lian Li Cases. Dimension (W)70mm x (H)145mm x (D)30mm
Add your own Caption!!!
[/CENTER]
Mnpctech.com
PostPosted: Fri Jun 03, 2011 9:33 am    Post subject: Reply with quote
We will be swapping the hardware from NZXT's 5.25 bay Sentry Fan Controller into the top cover, available from performance-pcs, here
E.E.L Ambiense is having fun with making captions too!
Mnpctech.com
PostPosted: Sat Jun 04, 2011 3:39 am    Post subject: Reply with quote
Hey Kids, It's Billet on a skid!
I was focused on making a dent in our work load, so I didn't take a lot of photos last night...
First layer is 1/8" thick smoked grey, cast acrylic.
these will 3/16 mounting holes
Starrett spring loaded center punch..
Using counter bore bit to debur holes
Flush.
(hint: my lanboy air review)
Mnpctech.com
PostPosted: Sun Jun 05, 2011 2:41 am    Post subject: Reply with quote
This morning I'll be sleeving the Sentry this Silverstone FP34S Premium 3.5inch Bay Card Reader & Front I/O combo module, David chose this model mainly for it's card reader and headphone jack. It's from performance-pcs here It will be mounted in the new top panel. I chose Bulgin's "Orange Dot" for the Main Power button from performance-pcs, here
The Sentry's display screen will be mounted in the top bezel opening. A 22mm Bulgin "Orange Dot" vandal resistant switch will be the Power button.
another caption by EEL :clap:
Mnpctech.com
PostPosted: Sun Jun 05, 2011 11:27 am    Post subject: Reply with quote
3.5" HD trays painted Red Enamel and HD cage painted Black Enamel.
another caption by EEL!
Mnpctech.com
PostPosted: Mon Jun 06, 2011 3:49 pm    Post subject: Reply with quote
Tonight we'll be milling the aluminum panels and inlay plate for the side panel with the USS Enterprise (NCC-1701) design, which will be slightly larger than whats show in this screenshot.
The top cover will have a compartment...hmm for what?
The compartment lid consists of one sheet of 1/8" thick aluminum and 1/8" Opaque red cast acrylic
Mnpctech.com
PostPosted: Tue Jun 07, 2011 4:47 am    Post subject: Reply with quote
Last night the larger aluminum side panel plates took two hours apiece to mill. They exceed the travel space of the mill, so they had to be re-positioned for each side.
Made a temporary Tapping block as guide when manual tapping blind screw holes on backside of the larger aluminum panel.
Blind hole tapped for 8/32 machine screw
Caption by EEL!
Mnpctech.com
PostPosted: Tue Jun 07, 2011 5:14 pm    Post subject: Reply with quote
Sanded edges and removed mill trails on the aluminum panels today.
Mnpctech.com
PostPosted: Wed Jun 08, 2011 5:32 am    Post subject: Reply with quote
USS Enterprise cut in 1/8" thick aluminum exterior plate.
Mnpctech.com
PostPosted: Wed Jun 08, 2011 10:10 am    Post subject: Reply with quote
Finished 1/8" thick Opaque Red acrylic plates in the mill. They will mount inside the machined aluminum exterior plates, as shown in drawing... I'll mount these this afternoon
Post new topic   Reply to topic    The Mother Board Forum Index -> Modding Work logs All times are GMT - 8 Hours
Page 1 of 3
