It is currently Fri Jul 10, 2020 1:46 pm
 Post subject: Windows vulnerability
PostPosted: Wed Jan 05, 2011 2:20 am
there's a biggy out there once again:
http://www.microsoft.com/technet/securi ... 90606.mspx
and just disabling the dll is about the most crude solution I have seen so far... something really wrong there...
PostPosted: Wed Jan 05, 2011 6:28 am
Doesn't affect Win 7 or the latest Server 2008, just XP, Vista, and the older server OS's. Still a nasty one, though.
Faster than the speed of snot
PostPosted: Wed Jan 05, 2011 11:41 am
http://www.politicalwrinkles.com/tech-h ... tc-14.html
"Workarounds
Workaround refers to a setting or configuration change that does not correct the underlying issue but would help block known attack vectors before a security update is available. Microsoft has tested the following workarounds and states in the discussion whether a workaround reduces functionality:
• Modify the Access Control List (ACL) on shimgvw.dll
To modify the ACL on shimgvw.dll to be more restrictive, run the following commands from a command prompt as an administrator:
For 32-bit editions of Windows XP and Windows Server 2003:
Echo y| cacls %WINDIR%\SYSTEM32\shimgvw.dll /E /P everyone:N
For 64-bit editions of Windows XP and Windows Server 2003:
Echo y| cacls %WINDIR%\SYSWOW64\shimgvw.dll /E /P everyone:N
For 32-bit editions of Windows Vista and Windows Server 2008:
takeown /f %WINDIR%\SYSTEM32\SHIMGVW.DLL
icacls %WINDIR%\SYSTEM32\SHIMGVW.DLL /save %TEMP%\SHIMGVW_ACL.TXT
icacls %WINDIR%\SYSTEM32\SHIMGVW.DLL /deny everyoneF)
For 64-bit editions of Windows Vista and Windows Server 2008:
takeown /f %WINDIR%\SYSWOW64\SHIMGVW.DLL
icacls %WINDIR%\SYSTEM32\SHIMGVW.DLL /save %TEMP%\SHIMGVW_ACL32.TXT
icacls %WINDIR%\SYSWOW64\SHIMGVW.DLL /save %TEMP%\SHIMGVW_ACL64.TXT
icacls %WINDIR%\SYSWOW64\SHIMGVW.DLL /deny everyoneF)
Impact of Workaround: Media files typically handled by the Graphics Rendering Engine will not be displayed properly.
How to undo the workaround:
Run the following commands from a command prompt as an administrator:
cacls %WINDIR%\SYSTEM32\shimgvw.dll /E /R everyone
cacls %WINDIR%\SYSWOW64\shimgvw.dll /E /R everyone
icacls %WINDIR%\SYSTEM32 /restore %TEMP%\SHIMGVW_ACL.TXT
icacls %WINDIR%\SYSTEM32 /restore %TEMP%\SHIMGVW_ACL32.TXT
icacls %WINDIR%\SYSWOW64 /restore %TEMP%\SHIMGVW_ACL64.TXT"
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
