clearkjustin36 Pilgrim
Posted: Tue Dec 21, 2010 2:18 am Post subject: fix icon for offline network folders |
Hi,
I am running windows XP in my PC and I have a simple home network setup. I haven't made any changes in the setup neither in configuration nor in network.
I just want to know how I can fix icon for offline network folders so that I can see all the available offline files.....Please suggest |
fussnfeathers Mobo-fu Master
Joined: 04 Dec 2008 Posts: 3096 Location: Right behind you
Posted: Tue Dec 21, 2010 4:41 am Post subject: |
How do you mean, "fix"? The icon isn't showing correctly, or you can't access shared folders? _________________ Faster than the speed of snot |
Hardware Junkie Mobo-fu Master
Joined: 25 Jan 2001 Posts: 19354 Location: 00000h - 0000Fh
Posted: Tue Dec 21, 2010 8:58 pm Post subject: |
If you have always used Offline Files, and now its suddenly not working, then your best bet is to take off the synchronization and re-add it.
XP file sync never really worked right... _________________ "Imagination is the only weapon in the war against reality." -Jules de Gautier
Posted: Wed Dec 22, 2010 11:05 pm Post subject: |
| yes the icon isn't showing correctly. please help!!! |
bdub Black Belt 3rd Degree
Joined: 19 Feb 2003 Posts: 3337 Location: Washington D.C.
Posted: Thu Dec 23, 2010 6:53 am Post subject: |
right click the shortcut, goto properties, customize tab, change icon button... should be a ble to find it in there, if not then it has been deleted, but you can prolly find the file online somewhere. _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
zalman cpns5x performa hs/fan
antec neo he 650r
kingston hyperx 3k ssd 120GB
seagate 500GB HDD 32M cache
seagate 750GB HDD 32M cache
hitachi 1TB HDD 32M cache
lg wh14ns40 bd burner
Posted: Fri Dec 24, 2010 1:37 pm Post subject: |
Recreate the Icon-Cache file by deleting it
1.Delete the hidden file ShellIconCache (Win9x/NT4/2k):
C:\Windows\ShellIconCache or C:\Winnt\ShellIconCache
Note in WinXP each user has their own file that is called Iconcache.db:
C:\Documents and Settings\Your User Name\Local Settings\Application Data\Iconcache.db
Note in Vista each user has their own file that is called Iconcache.db:
%USERPROFILE%\AppData\Local\Iconcache.db
2.Close down all explorer.exe processes using the Task Manager (Or else it will create a faulty file during logoff/restart)
3.Use the Task Manager (CTRL+SHIFT+ESC) to launch the explorer.exe again (Or press CTRL+ALT+DEL to perform a restart/logoff)
4.When the Windows Explorer (explorer.exe) starts again, it will recreate a correct Icon-Cache file _________________ Faster than the speed of snot |
Posted: Mon Dec 27, 2010 2:36 am Post subject: |
Thanks friends!!!
I appreciate your help.
I got a very easy solution from a website called completepcpedia. com. I just followed the steps provided there and it worked for me.
thanks,
Clearkjustin36 |
