AmEv Black Belt
Joined: 20 Jun 2009 Posts: 654 Location: Wanting to be at these forums, but not as active as they
Posted: Wed Nov 17, 2010 4:13 pm Post subject: Updated BIOS, now cannot fold. |
I updated my D865GBF MoBo; now it won't fold, saying that "there is an instance already running".
Any thoughts? _________________ I'm gonna get my new hardware. And my worklog here. |
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36375 Location: Netherlands, Breda
Posted: Thu Nov 18, 2010 1:43 am Post subject: |
sounds like windows crashed out rather than nicely shutdown before the bios upgrade. I don't know at what point the previous unit was but I suggest you clean out the folding folder and reinstall the folding client. _________________ We hate rut, but we fear change.
Pette Broad Black Belt 5th Degree
Joined: 10 Jul 2001 Posts: 5485 Location: Flintshire, U.K
Posted: Thu Nov 18, 2010 5:35 pm Post subject: |
I can think of a couple of things.
#1 It's folding as a service.
#2 It's running from your startup menu.
#3 Your Machine ID's need changing, run using the -config flag.
Do a CTL/ALT/DEL and see what you have running and check under Admin tools that you don't have it running as a service.
| Quote: | | I don't know at what point the previous unit was but I suggest you clean out the folding folder and reinstall the folding client. |
Yes, that should fix it, but you'll lose any work in progress.
Pete _________________
Karlsweldt Enlightened Master
Posted: Fri Nov 19, 2010 7:18 am Post subject: |
The status of most services or programs can be set from the Administrator Tools/Services panel. Many automatic-start processes must be left as-is, or Windows may fail to respond. But other programs or services that are auto-launched on start up can be reset to 'manual' launch.
My F@H processes are linked with desktop icons for manual start. They do appear as active on the task bar. They can be started/stopped as needed. If such programs are auto-launched at start up, they will never really shut down if required to.
Hope you do not loose the work progress on the units. _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
AmEv Black Belt
Posted: Mon Nov 22, 2010 9:28 am Post subject: |
Yeah....
I downloaded the TaskBar one, and copied the shortcut into the StartUp.
Removed from StartUp, manually started after a reboot, re-copied, and now it's fixed.
albiet I lost 1000/2000...... _________________ I'm gonna get my new hardware. And my worklog here. |
