toby1ne Pilgrim
Posted: Sun Nov 07, 2010 8:37 am Post subject: Dell dimension 2400 |
Hi, my mum has the above and would like to add some more ram. I can get some decent ram from a number of places, athough im not sure what the mobo can handle per slot! below is the spec....
DDR SDRAM
Memory connectors: two
Memory capacities: 128-, 256-, or 512-MB
Minimum memory: 128 MB shared DDR SDRAM
NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
Maximum memory: 2 GB
Memory type: PC2100 (266-MHz) or PC2700 (333-MHz) DDR SDRAM (non-ECC)
My question is: if each slot can hold 512mb ram, how can the maximum amount of ram be 2gb? there are only two slots!
Thanks, T. |
Mr T Enlightened Master
Posted: Sun Nov 07, 2010 8:56 am Post subject: |
Welcome to the motherboards.org....
I get asked this question a lot and always ask them to bring the system into the shop so we can get some RAM that will work properly.... What you find on elderly systems like this is that they were produced before 1Gb sticks were heard of in the home use zone, so basically literature and BIOS's just didn't support it...
So,
I would take it into a PC shop (reputable) and get them to fit 1Gb sticks of DDR333 (DDR400 should work but run at 333) and see if they work.. If they don't then it saves a lot of messing about returning stuff, recovering any corrupt files in the rare event the system crashed and so on...
However, if the system is running fine and dandy, albeit a bit slow, I would be sorely tempted to invest in a completely new setup. It is probably the more feasible option in the long run... _________________ I have been programming on computers since the ZX81.
toby1ne Pilgrim
Posted: Sun Nov 07, 2010 9:15 am Post subject: |
Hi, thanks for your reply.
I think she wants to keep the pc because there isnt actually anything wrong with it...apart from the fact its so dreadfully slooow.
If the ram is the correct spec and if i put 512 in each slot (from a twin pack of ram) is it unlikely to work? |
Posted: Sun Nov 07, 2010 11:15 am Post subject: |
It is more likely to work, however DDR had loads of compatibility issues... Most of the time all is ok, but sometimes not... Getting hold of DDR new is not that easy unless you pay over the odds from someone like Crucial, but at least it is guaranteed to work... _________________ I have been programming on computers since the ZX81.
Big Jake Black Belt 1st Degree
Posted: Mon Nov 08, 2010 11:09 am Post subject: |
I agree with Mr. T that on a system as old as yours that you may be better off just replacing the unit all together. Other components can fail such as the power supply.
But if you want to go the upgrade route, here is a link from Crucial's web site that says the 1 GB sticks of memory will work in the 2400 series.
http://www.crucial.com/store/listparts.aspx?model=Dimension%202400%20Series
Before you invest in the memory, either mail order or at your local computer shop, remenber that there can be other reasons for slow performance, such as a full/fragmented disk drive, malware and so forth.
Jake _________________
Main Rig: ASUS P6X58D-E, i7-930, OCZ3X1600R2LV6GK, ATI Radeon 5770 PCP&C 750W PSU
Lenovo T61 widescreen, 4GB RAM, 500GB 7200, NVIDIA Quadro NVS 140M 512 MB, Win 7 Ultimate 64, Server 2008 and XP Pro
ASUS P5K Deluxe, E8400 3.0GHz, 2x2GB OCZ Reaper DDR2 800 CL 6, 3.5 TB 7200rpm, ATI Radeon 5770, Win 7 Ultimate 64, OCZ 750 W PSU |
lannaheim Brown Belt
Joined: 24 Jun 2003 Posts: 350 Location: Washington, DC
Posted: Wed Nov 10, 2010 3:50 am Post subject: |
I am big on helping to revive little-old-lady computers...up to a point.
Cash in the Dell. "Nothing wrong apart from it running excruciatingly slow" is not worth more head-banging. Save data and ditch it. ZT sells nice systems for less, and better than freaking Dell... _________________ Outside of a dog, a book is man's best friend. Inside a dog, it's too dark to read.
--- Groucho Marx
A member of Folding Team number 33258 for a cure for PARKINSONS DISEASE |
