Toby B. Lead Mobo-fu Master
Posted: Mon Nov 01, 2010 7:08 pm Post subject: getting back into it... |
well I now have a new desktop and a new (about a year old now) laptop. Im interested in getting them folding but am not sure on best setup..
Both systems are running Windows 7 Home Premium 64 bit.
Desktop is running an AMD Athlon II 250 Dual Core and has 3GB of RAM
Laptop is running an Intel i3 M330@2.13GHz and has 4GB of RAM _________________ We Help You. You Can Help Us!
Link to us from your pages |
Karlsweldt Enlightened Master
Posted: Tue Nov 02, 2010 1:16 pm Post subject: |
Good to have you back in the "fold".
Best would be the Console version on the desktop, set your prefs and "let 'er rip" so to speak. If you have a multi-core CPU, it can do two WUs simultaneously, as long as they have different folder names (or on different drives). The laptop would be best with only one WU at a time. Of course, it would have to always be on AC power, and may need a cooling plate or other means to keep it at a happy temperature. Should run normally with the lid closed. Guess you know the link for the Console version commands..
http://folding.stanford.edu/console-userguide.html .
I use a Console control for each WU, launched from a desktop link.. not as a service-related start.
I would do a 24/7 folding routine, but electric costs by me are at $0.175 per KWH! Hope they are less in your area. _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
Pette Broad Black Belt 5th Degree
Joined: 10 Jul 2001 Posts: 5487 Location: Flintshire, U.K
Posted: Tue Nov 02, 2010 4:40 pm Post subject: |
Hi Toby,
Good to see you here again. Karl has pretty well summed it up, just a couple of things to add. After you've added your flags (-advmethods is usually best) and you run the program for the first make sure that after you've added your user name, team number, etc that you proceed to the advanced settings. You can leave them all on the default setting except for the machine ID settings which on each instance must be set differently. The other thing worth mentioning is what sort of graphics card you have in the AMD machine. If you have an ATI or NVidia card then this can be utilised too. Not sure exactly what ATI cards are supported but anything from an 8600 Nvidia card can be used to great effect.
Cheers,
Pete _________________
~PJ~ Black Belt 5th Degree
Posted: Sat May 28, 2011 1:22 pm Post subject: |
Have to say I'm not sure how to set it up twice for dual core... _________________
Peace for its people,
Love in our lives,
Delight in the good,
Forgiveness for past wrongs,
And from now on a new start. |
Posted: Sun May 29, 2011 5:06 am Post subject: |
Setting up F@H for dual-core should be no different than the previous generation CPU types with HT. As long as each program folder has a unique name, there should be no problems with crossing operations. You could use "F@H1", "F@H2" or "Folding@Home1", or other. As long as each folder has the unique name. Of course the programming in each would need to be duplicated, and your unique user name and machine type would be added to the start-up configuration. Stanford will add the unique serial # ID to your configuration. _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
