redxxd Pilgrim
Posted: Fri Oct 29, 2010 12:51 am Post subject: Intel DH55TC Motherboard unable to Boot |
Hello!!
I am assembling my first CPU, and ran into some problems. My case unit (outer cover) has only 8-pin front panel wires while the motherboard has 9 pins for the front panel. Should the 9th pin (+5v) be left without any connection? The manual doesn't specify what needs to be done.
I am unable to boot. The green standby light glows without flickering. When I press the on/off button, the cpu fan rotates for less than one-tenth of a second.
I've made several attempts of reconnecting without success.
Anything else that I could try?
Please let me know what I could be doing wrong. |
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36384 Location: Netherlands, Breda
Posted: Fri Oct 29, 2010 12:58 am Post subject: |
what brand/model is the case. what CPU are you using, what brand/model memory modules are you using, what brand/model power supply are you using, did you make sure the heatsink/fan is properly mounted on the CPU? Did you make sure no standoff is causing a short between the board and casing etc.
Check the sticky post for troubleshooting new (re)builds. _________________ We hate rut, but we fear change.
redxxd Pilgrim
Posted: Fri Oct 29, 2010 1:32 am Post subject: Thank You... but I still have the same issues. |
The case is an unbranded case. (Zebronics CS-10)
CPU - Core i3
memory - DDR3 (1*2 GB)
power supply - unbranded
(I bought them at a shop that informed me that these were meant to work with each other)
I did try re-inserting the heatsink/fan but that didn't make a difference.
I also tried removing the memory and starting the motherboard alone just with only the CPU. standby light alone and cpu fan doesn't rotate
Does the motherboard need only 8 pins connected for front panel?
Is there a way of turning the motherboard on by shorting certain terminals to check if the casing is faulty?
Also, How do I ensure that the standoffs are not causing any shorts. I have 6 screw locations that are directly screwed to the case. Also, I tried the 6 locations with different types of metallic screws. |
redxxd Pilgrim
Posted: Fri Oct 29, 2010 1:44 am Post subject: |
Also,
The Case came with only one standoff like the one in wikipedia
The rest of the holes are placed with normal screws. |
Posted: Fri Oct 29, 2010 12:43 pm Post subject: |
some i3 need a newer bios to work:
http://processormatch.intel.com/CompDB/SearchResult.aspx?BoardName=DH55TC
If just CPU fitted (nothing else connected, no harddisk etc) it should beep when powered on. Is the wiring from your case in a single 8-pin connector? Or do you have 4 separate 2pin connectors?
Preventing from shorting: if the case screw places are matching with the holes in the motherboard it is fine. Just no other screw places where there are no holes in the board. When in doubt, test outside the case on a cardboard box and connect the power supply.
Manually briefly shorting two pins that have PWR SW next to them. Power switch.
For sure if the shop says it should work together they will be able to help you out with this too. _________________ We hate rut, but we fear change.
