fussnfeathers Mobo-fu Master
Posted: Mon Aug 23, 2010 11:15 pm Post subject: |
| evasive wrote: | | Hardware Junkie wrote: |
Additionally, I am not seeing a BIOS chip on the board. I think that empty socket near the keyboard is where that is supposed to be.
no that is for the 80287 co-processor. for those of you never seeing SIPP memory module sockets: you're right, the pins on the memory sticks kept breaking of, that is why they quickly went to the memory slots you may know from the pentium boards. those of you with a few more years, either in age or in experience would recognize these babies directly though. I may even own a board with them. |
Ye Gods, how many of those did I install with no instructions? _________________ Mine go to 11 |
jeremfg Pilgrim
Posted: Tue Aug 24, 2010 9:34 am Post subject: |
| Karlsweldt wrote: | | Finally found the link to this site which lists many older mobo designs. But found nothing close. |
I visited this website before posting, and didn't find anything either.
| Hardware Junkie wrote: | | Just went through the 286 boards in TH99 and didn't find any matches... |
Thanks for bringing that up... It's been a long time since I last visited this website (5+ years) and had forgot about it.
And I did find my motherboard on TH99! It's there! But it doesn't help much though! It's marked as "unidentified"
Here's the link!
On their schema. there's a number : MH2214. But I have no idea what it means! |
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36380 Location: Netherlands, Breda
Posted: Tue Aug 24, 2010 10:51 am Post subject: |
So Vtech as manufacturer, 286/16 ISA as type number is not going to be good enough? Because that is as good as it will get most likely. provided you can get it to boot and reply with the bios identification string that might hold the model number. But i would not count on that.
You did do a proper job on picking it out of the long list of motherboards. _________________ We hate rut, but we fear change.
Hardware Junkie Mobo-fu Master
Joined: 25 Jan 2001 Posts: 19349 Location: 00000h - 0000Fh
Posted: Tue Aug 24, 2010 12:39 pm Post subject: |
| jeremfg wrote: |
Here's the link!
If that's the board, that's as much info as your going to find I think.
Time to boot the sucker and hope for the best. _________________ "Imagination is the only weapon in the war against reality." -Jules de Gautier
jeremfg Pilgrim
Posted: Tue Aug 24, 2010 1:14 pm Post subject: |
| evasive wrote: | | So Vtech as manufacturer, 286/16 ISA as type number is not going to be good enough? Because that is as good as it will get most likely. provided you can get it to boot and reply with the bios identification string that might hold the model number. But i would not count on that. |
It's very good! But I'm kinda of always wanting more . It's never enough I'm like that!
With everything all of you have said, I've became conviced that this motherboard was pulled from a Vtech Laser 286
I'm in the process of trying to confirm that with them.
They have at least the user manual (if not the computer that goes with it), so they might be able to confirm my belief!
If it can be confirmed, I might also be available to get a scan of this manual!
As for booting it up, I might do that when I get to it (it's not stored in my home right now).
I'll get back when I know more! |
Karlsweldt Enlightened Master
Posted: Tue Aug 24, 2010 2:12 pm Post subject: |
If indeed that user manual is for the 286 mobo, then you can decipher the jumper settings and that 4-gang DIP switch. Back then, the parallel port did not have a 'default' setting of 378h.. more like 3BC, following the original IBM scheme. There also should be one jumper for setting the video mode, either monochrome or color. There also may be a lockout feature on the BIOS.
As to memory, you definitely will need those SIPP modules. Two may work, but may be best to try with four identical modules. 80ns or 70ns should work well on that board.
There should be two connection pins at the edge, marked "turbo" that allows switching from high speed (16 Mhz) to low speed (8~12 Mhz) so as to accommodate older programming that ran on system clock timing, rather than real-time clock. _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
Pette Broad Black Belt 5th Degree
Joined: 10 Jul 2001 Posts: 5485 Location: Flintshire, U.K
Posted: Tue Aug 24, 2010 5:10 pm Post subject: |
Amazing that you can still get spares for boards of that age.
Pete _________________
jeremfg Pilgrim
Posted: Tue Aug 24, 2010 5:19 pm Post subject: |
| Karlsweldt wrote: | If indeed that user manual is for the 286 mobo, then you can decipher the jumper settings and that 4-gang DIP switch. Back then, the parallel port did not have a 'default' setting of 378h.. more like 3BC, following the original IBM scheme. There also should be one jumper for setting the video mode, either monochrome or color. There also may be a lockout feature on the BIOS.
There should be two connection pins at the edge, marked "turbo" that allows switching from high speed (16 Mhz) to low speed (8~12 Mhz) so as to accommodate older programming that ran on system clock timing, rather than real-time clock. |
Thanks! I already knew all that...
As for deciphering jumpers, I can already do that with the information found on TH99, which I posted earlier!
By the way, there isn't a parallel port on this board. However, if I'm correct in saying that this board was pulled from a Vtech Laser 286 computer, that computer had it's own 8-bit ISA I/O Card which provided parallel and serial port. And apparently, this card can still be found (bought) on the web!
Also, I don't really need SIPP memory to test the board, I could get up to 1Mb of RAM using only DIP memory (According to what I found on TH99). But if I would go as far as use it, I would definitely get 2 full banks of SIPP modules (4x1Mb) to get the maximum out of it, 4Mb. |
Posted: Wed Aug 25, 2010 3:59 am Post subject: |
yep, not all of the DIP sockets were for cache memory.
However, if you are going to use the 4MB sipp's, you may want to fit some cache memory chips as well, might make this system useable. Most likely those need to be 10ns or 12ns chips.
Any 8bit or 16bit ISA multi I/O card should work, you may even be able to fit an IDE controller card. _________________ We hate rut, but we fear change.
jeremfg Pilgrim
Posted: Fri Aug 27, 2010 9:30 am Post subject: |
I'm still unclear about that...
Where would the cache memory go?
When I read the info on TH99, all the sockets are for DIP DRAM!, and the empty one for a math co-processor!
Unless it has something to do with the parity chips, or something I don't get!
I guess it has something to do with the 2 choices of DIP which interleave themselves across "Bank 1B" (as shown on TH99).
Could you please explain this interleaving giving two choices? Thanks! |
