Chevalier Pilgrim
Posted: Tue Aug 10, 2010 8:43 am Post subject: I have detached SATA socket from motherboard! |
I have an ASUS P5B Premium motherboard and whilst removing several SATA cables I failed to press the release clip and inadvertently pulled the SATA plastic shroud from the motherboard leads. The leads and the plastic shroud are OK but I do not know how to put back the plastic shroud. Do I just supeglue back the plastic shroud or is the matter more complicated than that?
Can anyone please offer any advice? |
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36408 Location: Netherlands, Breda
Posted: Tue Aug 10, 2010 11:05 am Post subject: |
that depends on what it looks like now... is the center piece still there? _________________ We hate rut, but we fear change.
Chevalier Pilgrim
Posted: Tue Aug 10, 2010 11:34 am Post subject: |
| evasive wrote: | | that depends on what it looks like now... is the center piece still there? |
The centre piece exists in good condition and pins on the motherboard are all there and fairly straight. |
Karlsweldt Enlightened Master
Posted: Tue Aug 10, 2010 2:11 pm Post subject: |
Those "super" glue types would not be the best for affixing a data cable socket. Better would be some hot glue around its base. Best would be an epoxy type adhesive.
Note the other SATA sockets, there is a 'key' at one end of the center strip. Ensure that all sockets are mounted the same way, then gently press the socket straight down to the board surface.There are only 7 connection pins for the original SATA cable. The e-SATA connections total 15. If all the pins are still straight and intact, you may be lucky. SATA connections: _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
Hardware Junkie Mobo-fu Master
Joined: 25 Jan 2001 Posts: 19354 Location: 00000h - 0000Fh
Posted: Tue Aug 10, 2010 3:43 pm Post subject: |
Hot glue is your best bet. I see a lot of people using this in the PC world to secure cables for systems that are being shipped.
A lot of hot glue melts plastic so be careful if you go that route. _________________ "Imagination is the only weapon in the war against reality." -Jules de Gautier
Chevalier Pilgrim
Posted: Wed Aug 11, 2010 1:56 am Post subject: |
| Karlsweldt wrote: | Those "super" glue types would not be the best for affixing a data cable socket. Better would be some hot glue around its base. Best would be an epoxy type adhesive.
Note the other SATA sockets, there is a 'key' at one end of the center strip. Ensure that all sockets are mounted the same way, then gently press the socket straight down to the board surface.There are only 7 connection pins for the original SATA cable. The e-SATA connections total 15. If all the pins are still straight and intact, you may be lucky. |
Those are great tips. Thank you. |
Chevalier Pilgrim
| Hardware Junkie wrote: | Hot glue is your best bet. I see a lot of people using this in the PC world to secure cables for systems that are being shipped.
A lot of hot glue melts plastic so be careful if you go that route. |
Many thanks for the heads up. |
