Olivetti M480-30 BIOS
Goto page 1, 2, 3, 4  Next
Post new topic   Reply to topic    The Mother Board Forum Index -> BIOS
Retrocomputer
PostPosted: Sun Jul 25, 2010 2:51 pm    Post subject: Olivetti M480-30 BIOS Reply with quote
Hi everyone!
I'm Davide Fabrici (call me David...) from Italy. I'm 15 (16 on the 04th November). Please forgive me for my bad English (you'll say if I got actually a bad one... ) big grin
But let's go straight to my problem.
I've got a very old Olivetti M480-30 (ext. 1989/1990) in which I can't enter in the BIOS.
System Specs:
MoBo: BA 865 or BA 952
CPU: Intel i486 DX @ 25 mHz;
Bios: Olivetti proprietary (seems so...)
Version: unknown...
So, can somebody help me? What should I do to enter the BIOS?
The system is working, but the PC won't recognize the HDD.
Take a look on what the PC says while booting.
Then, it stops here, having no HDD.
If you need more infos, feel free to ask me.
Thanks,
David(e)
View user's profile Send private message Send e-mail
PostPosted: Sun Jul 25, 2010 9:00 pm    Post subject: Reply with quote
cap24.pdf from here:
http://www.elhvb.com/mboards/olivetti/systems1.html
click on the link and let it send the email, I'll reply with that document.
Retrocomputer
PostPosted: Mon Jul 26, 2010 2:58 am    Post subject: Reply with quote
Oh, thanks! E-mail sent. What's that document about?
Thanks a lot,
David(e)
PostPosted: Mon Jul 26, 2010 3:26 am    Post subject: Reply with quote
it is the service manual for these systems. at one time these were public online at olivetti but since olivetti PCs/Servers has decided to take this offline I decided to setup this service.
Retrocomputer
PostPosted: Mon Jul 26, 2010 3:28 am    Post subject: Reply with quote
That's GREAT!! I silently and hopefully wait.
David(e)
Retrocomputer
PostPosted: Mon Jul 26, 2010 8:51 am    Post subject: Reply with quote
Oh yes, please, if you can, inform me when you have sent the manual. lachen oops
Thx,
Davide
PostPosted: Mon Jul 26, 2010 9:20 am    Post subject: Reply with quote
Just got home from work. manual sent. Most likely you are trying to use a disk that isn't supported, your machine is quite old and they used an actual model list of drives that you could fit. Much more strict than these days of autodetect.
Retrocomputer
PostPosted: Mon Jul 26, 2010 11:00 am    Post subject: Reply with quote
Hi evasive. Just checked, and it seems that I have some configuration issues.
I've got a supported HDD, a 212 MB Conner CP3200F. But, reading your manual, I noticed that I miss a SCSI cable terminator, needed because of the SCSI controller model, the GO582; but I've searched, found and mounted it . big grin The second problem is that the HDD must be set with SCSI ID 6, on my drive, it means E2 & E3 jumpers shorted, as shown here:
. I tried, but it seems that those contacts' pitch isn't standard. Normal jumpers doesn't work. They doesn't fit on the contacts. Does anybody have this kind of jumpers?
Bye,
Davide
PostPosted: Mon Jul 26, 2010 11:26 am    Post subject: Reply with quote
hmm those are not easy to find. what you can do is take the metal bit out of a normal jumper and form that to make one that fits on those pins. I think the pins are smaller but the distance between them is the same.
Retrocomputer
PostPosted: Mon Jul 26, 2010 12:19 pm    Post subject: Reply with quote
Oh my god... I just hand built two jumpers, they short-circuit well, and guess?? Nothing changed, Hard Disk(s) Present: 0.
I must enter in that BIOS, how do I?
Thanks,
Davide
Post new topic   Reply to topic    The Mother Board Forum Index -> BIOS All times are GMT - 8 Hours
Page 1 of 4
