chieftex Brown Belt
Posted: Wed May 19, 2010 8:40 am Post subject: I made a silly, and installed an OS over itself |
I installed win xp, over winxp - on the same partition.
Yes I know, I know.
Anyway I now have a windows folder and a windows.0 folder that is the newer install. And I get asked which OS I want to boot, winxp or winxp.
Is there any easy way to remove this? _________________ Intel E4500 @ 2.2ghz (stock)
Asrock P45DE motherboard
2x 2GB Ballistix DDR2-800
Xfx HD 4890
2x hdds
2x odds
Antec NeoHE 500w PSU |
bdub Black Belt 3rd Degree
Joined: 19 Feb 2003 Posts: 3330 Location: Washington D.C.
Posted: Wed May 19, 2010 9:12 am Post subject: |
look at your boot.ini file with notepad, and edit it to only contain the os you want to start.
you can also right click my computer>properties>advanced tab>statup and recovery settings to edit said file or change parameters. _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
zalman cpns5x performa hs/fan
antec neo he 650r
kingston hyperx 3k ssd 120GB
seagate 500GB HDD 32M cache
seagate 750GB HDD 32M cache
hitachi 1TB HDD 32M cache
lg wh14ns40 bd burner
chieftex Brown Belt
Posted: Wed May 19, 2010 9:23 am Post subject: |
Much appreciated.
And then can I just delete the WINDOWS.0 folder? _________________ Intel E4500 @ 2.2ghz (stock)
Xfx HD 4890
2x hdds
2x odds
Mr T Enlightened Master
Posted: Wed May 19, 2010 9:52 am Post subject: |
Best not too, if it has references in the 'new' xp it may cause all sorts of difficulties... _________________ I have been programming on computers since the ZX81.
fussnfeathers Mobo-fu Master
Posted: Wed May 19, 2010 12:29 pm Post subject: |
Leave the old folder. When you do an over-the-top install like that, it merges your main OS files. If you delete it, most of your hardware won't work. Most of the OS won't work, for that matter. The only things that wind up fully seperated are the user folders, and even then, that's sketchy. Just edit out the boot.ini and leave it, unless you want to start over with a clean drive. _________________ Mine go to 11 |
