whiteboy Anti-Static Strap
Joined: 15 Jan 2003 Posts: 437 Location: Lehigh Acres, Fl
Posted: Wed Apr 14, 2010 11:44 am Post subject: high WU's low points? |
was looking at my stats and saw this
Day Points WUs
04.14.10 151 2
04.13.10 126 1
04.12.10 2,270 2
04.11.10 2,508 2
04.10.10 225 1,065
notice the last line..how can i post 1065 WU and only recieve 225 points!!..what i do get a bunch of units only worth 0.25 points or something? _________________ Amd Phenom 9500 Quad on a ECS a770m mobo
4 gigs ram
2 250 gig samsung sata HDs
2 lite on sata dvd burners
total cost under $600 built march 2008 |
Karlsweldt Enlightened Master
Posted: Wed Apr 14, 2010 3:21 pm Post subject: |
Stanford may have had server problems the week-end of April 3rd. I had a few units that would not submit until the 5th.
Some units are large, but work fast.. and are expected back within 24~36 hours, for full credit. Others may be small, but can take days to work.
The researchers at Stanford apply a credit score to each WU depending on its complexity and time line for submission. You probably know about the 'current projects' link from Stanford.. http://vspx27.stanford.edu/psummaryC.html . _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
Pette Broad Black Belt 5th Degree
Joined: 10 Jul 2001 Posts: 5485 Location: Flintshire, U.K
Posted: Wed Apr 14, 2010 4:53 pm Post subject: Re: high WU's low points? |
| whiteboy wrote: | was looking at my stats and saw this
Day Points WUs
04.14.10 151 2
04.13.10 126 1
04.12.10 2,270 2
04.11.10 2,508 2
04.10.10 225 1,065
notice the last line..how can i post 1065 WU and only recieve 225 points!!..what i do get a bunch of units only worth 0.25 points or something? |
I'd say that on the 10th, that you were "burning" units. If you check through your logs then you'll probably find that you were getting instant early unit ends...Another possibility is that you had a load of protomol units which can end at any time. Hmm, several other possibilities too, I'll check it out but it looks like a one day glitch of sorts.
EDIT, a quick review of the stats and you are the only one in our team with huge WU numbers. However, I found this team that is having massive spikes in WU numbers but not on the 10th
http://folding.extremeoverclocking.com/team_summary.php?s=&t=2164
Probably a bunch of bad units going round, but I can't be sure, can you have a look at your log and see what project number it was?
Thanks
Pete _________________
Posted: Thu Apr 15, 2010 2:23 pm Post subject: |
Had several units in the 100** series a bit over a week ago. Very unstable, worked only a few seconds and were terminated. They were in that 'protomol' class. _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
Posted: Thu Apr 15, 2010 4:32 pm Post subject: |
| Karlsweldt wrote: | | Had several units in the 100** series a bit over a week ago. Very unstable, worked only a few seconds and were terminated. They were in that 'protomol' class. |
Thanks for the info, I guess that's the problem.
