I can't get any work units
MrG
PostPosted: Wed Apr 14, 2010 10:45 am    Post subject: I can't get any work units Reply with quote
I can't get any work units. Here's my log:
[18:07:25] Loaded queue successfully.
[18:07:25] - Preparing to get new work unit...
[18:07:25] Cleaning up work directory
[18:07:25] + Attempting to get work packet
[18:07:25] - Will indicate memory of 2046 MB
[18:07:25] - Detect CPU.[18:07:25] - Autosending finished units... [April 14 18:07:25 UTC]
[18:07:25] Trying to send all finished work units
[18:07:25] + No unsent completed units remaining.
[18:07:25] - Autosend completed
Vendor: GenuineIntel, Family: 6, Model: 7, Stepping: 6
[18:07:25] - Connecting to assignment server
[18:07:25] Connecting to http://assign.stanford.edu:8080/
[18:07:26] Posted data.
[18:07:26] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:07:26] + Couldn't get work instructions.
[18:07:26] - Attempt #1 to get work failed, and no other work to do.
Waiting before retry.
[18:07:32] + Attempting to get work packet
[18:07:32] - Will indicate memory of 2046 MB
[18:07:32] - Connecting to assignment server
[18:07:32] Connecting to http://assign.stanford.edu:8080/
[18:07:33] Posted data.
[18:07:33] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:07:33] + Couldn't get work instructions.
[18:07:33] - Attempt #2 to get work failed, and no other work to do.
[18:07:50] + Attempting to get work packet
[18:07:50] - Will indicate memory of 2046 MB
[18:07:50] - Connecting to assignment server
[18:07:50] Connecting to http://assign.stanford.edu:8080/
[18:07:51] Posted data.
[18:07:51] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:07:51] + Couldn't get work instructions.
[18:07:51] - Attempt #3 to get work failed, and no other work to do.
[18:08:18] + Attempting to get work packet
[18:08:18] - Will indicate memory of 2046 MB
[18:08:18] - Connecting to assignment server
[18:08:18] Connecting to http://assign.stanford.edu:8080/
[18:08:19] Posted data.
[18:08:19] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:08:19] + Couldn't get work instructions.
[18:08:19] - Attempt #4 to get work failed, and no other work to do.
[18:09:01] + Attempting to get work packet
[18:09:01] - Will indicate memory of 2046 MB
[18:09:01] - Connecting to assignment server
[18:09:01] Connecting to http://assign.stanford.edu:8080/
[18:09:02] Posted data.
[18:09:02] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:09:02] + Couldn't get work instructions.
[18:09:02] - Attempt #5 to get work failed, and no other work to do.
[18:10:23] + Attempting to get work packet
[18:10:23] - Will indicate memory of 2046 MB
[18:10:23] - Connecting to assignment server
[18:10:23] Connecting to http://assign.stanford.edu:8080/
[18:10:24] Posted data.
[18:10:24] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:10:24] + Couldn't get work instructions.
[18:10:24] - Attempt #6 to get work failed, and no other work to do.
[18:13:09] + Attempting to get work packet
[18:13:09] - Will indicate memory of 2046 MB
[18:13:09] - Connecting to assignment server
[18:13:09] Connecting to http://assign.stanford.edu:8080/
[18:13:10] Posted data.
[18:13:10] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:13:10] + Couldn't get work instructions.
[18:13:10] - Attempt #7 to get work failed, and no other work to do.
[18:18:40] + Attempting to get work packet
[18:18:40] - Will indicate memory of 2046 MB
[18:18:40] - Connecting to assignment server
[18:18:40] Connecting to http://assign.stanford.edu:8080/
[18:18:41] Posted data.
[18:18:41] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:18:41] + Couldn't get work instructions.
[18:18:41] - Attempt #8 to get work failed, and no other work to do.
[18:29:22] + Attempting to get work packet
[18:29:22] - Will indicate memory of 2046 MB
[18:29:22] - Connecting to assignment server
[18:29:22] Connecting to http://assign.stanford.edu:8080/
[18:29:23] Posted data.
[18:29:23] Initial: 0000; + No appropriate work server was available; will try again in a bit.
[18:29:23] + Couldn't get work instructions.
[18:29:23] - Attempt #9 to get work failed, and no other work to do.
My internet connection is working for all other applications. Any thoughts?
PostPosted: Wed Apr 14, 2010 3:30 pm    Post subject: Reply with quote
Stanford may have had some problems with servers the week-end of April 3rd. Had a few units that would not return, also got a "503" code from the servers. There may still be problems. That "503" code means that either a server is maxed out or is too busy with clients.
Try shutting down the F@H process, wait a minute or so, and restart. Works for me!
But funny that you get that "http://assign.stanford.edu:8080/" message.. you should note a true IP address, such as (***.**.**.***:8080). If you get this IP address, (0.0.0.0), that is invalid, a dead end!!
Pette Broad
PostPosted: Wed Apr 14, 2010 4:43 pm    Post subject: Reply with quote
There's a shortage of work for cpu clients at the moment and for the last few weeks actually. To get work you need to add the -advmethods flag and request small units. Make sure you have the latest client which is 6.23.
Cheers,
Pete
View user's profile Send private message Send e-mail
MrG
PostPosted: Thu Apr 15, 2010 12:45 pm    Post subject: Reply with quote
Thanks Pete.
I deleted all my Folding files and installed it all and now it works. However, I'm getting some crazy work units, 47 and 84 pointers lasting about 3 hours each??? I'm getting through dozens of them! eek
Pette Broad
PostPosted: Thu Apr 15, 2010 4:30 pm    Post subject: Reply with quote
MrG wrote:
Thanks Pete.
Yeah, I'm getting them too, I kinda like them. big grin
Pete
Page 1 of 1
