Mnpctech.com Black Belt
Posted: Sat Mar 20, 2010 2:54 pm Post subject: |
We made a stencil using the SF from the Stompfest event logo. It created a weird pattern, I call it Alien camouflage ..heh
Posted: Sun Mar 21, 2010 11:35 am Post subject: |
another look, and assembly of the feet and 140mm grill
Dusted the tops of the feet from 20" away with Black Self-etching primer...
Painted the 140mm fan grill.. should have done same effect, looking at it now.. oh welly! |
Posted: Mon Mar 22, 2010 9:28 am Post subject: |
I've gotta get it done soon, it's the main prize for the Stompfest LAN Event, April 10th - 11th in Indianapolis, http://www.stompfest.com/index.php?pageid=lanreg
Today I ordered COOLER MASTER eXtreme Power Plus 500W Power Supply today, so they could power up any lights or fans I've installed while it's on display. |
Posted: Mon Mar 22, 2010 12:09 pm Post subject: |
I really liked the speckled paint effect on the feet, so I'm repeating it on the rear 120mm Nautilus rear fan grill, http://www.mnpctech.com/120mm_Overkill_Fan_Grills.html
I masked off the face of the Nautilus grill, then painted the inner walls of the openings with Black self etching primer. flipped it over, and painted the backside as well.
I then removed the masking tape and held the can roughly 16" away from the grill and sprayed the perimeter of it. This is how you achieve the speckled paint effect.
Posted: Tue Mar 23, 2010 2:27 pm Post subject: |
Thanks for the comments! Here is the XIGMATEK XLF-F1254 120mm White LED Case Fans. These are rated 1500 RPM @ 61 CFM. Noise level is 20 dbA
Posted: Sat Mar 27, 2010 5:53 am Post subject: |
The Overkill "Nautilus" 120mm fan grill with XIGMATEK XLF-F1254 120mm fan installed.
Posted: Sun Mar 28, 2010 6:18 pm Post subject: |
here is the custom HAF 922 front bezel and fan grills after receiving 4th coat of Charcoal Grey Metallic paint today. The finish on the bezel will buffed out.
Posted: Mon Mar 29, 2010 3:30 pm Post subject: |
Here is the HAF 922 panel before executing the window and paint.
Right side panel, we'll be commemorating the 2010 Stompfest event with some artwork on this panel
Posted: Wed Mar 31, 2010 6:14 am Post subject: |
I started installing the Acoustical foam in the HAF 922 chassis yesterday, starting on the backboard. It has Adhesive backing for easy installation. It cuts very easily with a scissors or Xacto knife. This foam will help dampen noise generated from inside the 922.
http://www.mnpctech.com/Acoustical_Foam_Sheets_PC.html
Posted: Fri Apr 02, 2010 3:15 pm Post subject: |
The CM 500W PSU arrived DOA. ...Booo! I sent the CM PSU back and ordered this 550W OCZ "Fatality Edition" PSU. The purpose of the PSU is to power led fans and lighting while the case is displayed at Stompfest. Mnpctech assumes no liability for this OCZ PSU after it's served this purpose. (Contact that Wendal kid if it fails..j/k)
Newegg Link,
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341022
