bdub Black Belt 3rd Degree
Joined: 19 Feb 2003 Posts: 3337 Location: Washington D.C.
Posted: Wed Dec 30, 2009 1:07 pm Post subject: |
figured something like this was happening. had many many of these over the last week, and i am running several computers under 8 cores because of these, but i figure after a while we stop getting them in new instances, right?
i do use advmethods flag, how long before3 i can use it again without worrying over these bad units? _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
zalman cpns5x performa hs/fan
antec neo he 650r
kingston hyperx 3k ssd 120GB
seagate 500GB HDD 32M cache
seagate 750GB HDD 32M cache
hitachi 1TB HDD 32M cache
lg wh14ns40 bd burner
Pette Broad Black Belt 5th Degree
Joined: 10 Jul 2001 Posts: 5487 Location: Flintshire, U.K
Posted: Wed Dec 30, 2009 4:44 pm Post subject: |
| Ripshod wrote: | I don't understand what happened with this one but, apparently, the unit was finished, without error, at 52%
Far from being a loop of death, more an early bath. |
Well, this is how protomol handles EUE's. In future all cores will treat EUE's the same way. Of course you won't get full points for it, just the percentage that you completed.
Pete _________________
Posted: Wed Dec 30, 2009 4:48 pm Post subject: |
| bdub wrote: | figured something like this was happening. had many many of these over the last week, and i am running several computers under 8 cores because of these, but i figure after a while we stop getting them in new instances, right?
i do use advmethods flag, how long before3 i can use it again without worrying over these bad units? |
The new core is a vast improvement, I'm running a few of these and am not seeing any problems. I reckon its safe to use the -advmethods again . I would recomend that you first delete the b4 core before you do though, I'm not certain that the core update is forced by the server yet.
Posted: Wed Dec 30, 2009 4:58 pm Post subject: |
| Karlsweldt wrote: | | Have had a few work units terminate early. Some Beta-testing before full release is done, after lab trials.. to ensure consistent results while in the field. |
Beta Testing was pretty bad on these units. You wouldn't believe the havoc the original core release caused . For example, I had a run of units that finished after less than a second, hundreds of them actually, then there was the devastating effect they had on GPU folding as they sucked the CPU dry and left nothing for the GPU to work with. They would only run at 100% CPU usage, lots of the Beta Team refused to run them. The guy running the project then made the decision to put them into advmethods, maybe he was under pressure, who knows, but it was, to be kind, somewhat premature. Lots more problems and quick fixes followed but at last the core is now stable.
