Cooler Master 840 ATCS Case Mod ..::D-9::..
Postby fussnfeathers » Wed Dec 16, 2009 2:34 pm
Got a plan for securing those conduits? That much loose metal next to a powered up motherboard makes me a little fiddly.
Faster than the speed of snot
fussnfeathers
Postby Mnpctech.com » Thu Dec 17, 2009 9:53 am
Great question, I'll be using cable ties
There will be an MNU logo painted on this optical drive. Christopher likely traded something towards it, so he could view cd rom archived files from MNU perhaps?
More rust effects occur..
The new 600W Cooler Master Silent PRO didn't look right in a POS computer, it was treated to "rust lovin" as well.
Mnpctech.com
Postby Mnpctech.com » Thu Dec 17, 2009 2:24 pm
Intel Core 2 Duo 3.16 GHz Processor in Intel DX48BT2 Motherboard sent by Cooler Master for their display.
I'm looking at this Cooler Master HYPER N620 and wondering ""What Christopher do differently with it?"
Mnpctech.com
Postby AmEv » Thu Dec 17, 2009 3:24 pm
Paint the blades with flame stripes and have red and orange LEDs?
AmEv
Postby Mnpctech.com » Fri Dec 18, 2009 1:40 pm
White with rust is cool.
This method can be combined with 4.5" flexible tubing to isolate cool airflow. Imagine one end of the tube attached to a 120mm cooling fan in front of your case.
The 4.5" Flexible tubing can be found at Mcmaster, http://www.mcmaster.com/#duct-hose/=4zltce or you can "try" the "Heating & Cooling" department at hardware or home improvement stores like Home Depot or Lowes.
Supplies & Tools:
120mm Modder's Mesh Round fan grill, http://www.mnpctech.com/120mm_Custom_FanGrill.html
4.5" fan duct, http://www.mnpctech.com/FanDuct.html
4, #10 x 5/8" fan screws, http://www.mnpctech.com/thumbscrew.html">#10 x 5/8" fan screws</a>
120mm cooling fan.
Paint pen or pencil.
Tin snips.
Wire cutter.
Using a paint pen to trace the duct onto the round mesh grill.
a small wire cutter and Tin snips used to cut the 4.5" opening in the 120mm Modder's Mesh Round fan grill
You'll need to use the small wire cutter first, to make the initial cut before you can use the Tin Snips to cut the 4.5" hole.
Using Tin ship to cut the round mesh grill.
The result of you cutting should look like this.
120mm cooling fan. This fan has enclosed corners, you will need longer fan screws if you're mounting the fan onto something like a cpu cooler.
4, http://www.mnpctech.com/thumbscrew.html, #10 x 5/8" fan screws</a>
Mnpctech.com
Postby Mnpctech.com » Sat Dec 19, 2009 5:17 am
Our own Prawn canister is back from paint and ready for installation.
Original Prawn canister from District-9 movie
Mnpctech.com
Postby AmEv » Sat Dec 19, 2009 10:31 am
Holy cow, the accuracy! :mb_dropsjaw::
AmEv
Postby Mnpctech.com » Sun Dec 20, 2009 5:10 am
Thanks for the comment dude!
Yesterday I painted the 2x 120mm cooling fans from the Cooler Master HYPER N620, will post those photos soon!
140mm Aerocool Fan for the exhaust, was also painted Matte White
Fan Grill made from Round Modder's Mesh, http://www.mnpctech.com/moddersmesh.html
Mnpctech.com
Postby Mnpctech.com » Tue Dec 22, 2009 2:41 pm
Here is the Prawn canister installed, I've added a 4" White cold cathode light between the front intake plate and bezel.
Mnpctech.com
Postby AmEv » Tue Dec 22, 2009 6:24 pm
Well, you shouldn't have any airflow problems :lol:
Unless you're going to put a window in front of the canister. NOT a good thing if it gets knocked over. :o
AmEv
PreviousNext
Return to System Modification
