Mobo reccomendation
Mobo reccomendation
Postby AmEv » Mon Sep 21, 2009 3:17 pm
Got a case to mod. Old innards:
100mhz IBM processor
800MB HDD
??KB FPO/EDO (not sure on either)
PVR/TV tuner (the ONE thing I like about it: in-room TV and game console hook-up capabilities)
OK. It was an old AIO. Dangerous work, but hey. I'm still alive to post, aren't I?
But I did a little experimenting, and found out, with an LCD in place, I could put in a mATX board. Was able to route cables (data and power) no problem.
Also, I got a P4 3.0GHz. Meant to upgrade Compaq, but one pin was transposed. :oops:
My question:
What would be the best mATX (not necessarily the BEST) board that supports my p4? And where could I get it?
AmEv
Postby o1die2 » Tue Sep 22, 2009 2:17 am
Is your p4 cpu socket 775 or 478?
o1die2
Postby AmEv » Tue Sep 22, 2009 2:08 pm
Not sure. Here's the writing on it:
Intel (M) (C) '01
PENTIUM(R)4
3 GHZ/512/800
5L6WK MALAY
0401A470
AmEv
Postby o1die2 » Tue Sep 22, 2009 8:09 pm
You have a socket 478 northwood. Computer geeks has an asus p4sd micro atx board for about $43 with free shipping. Ascendtech.us and 3b tech may also carry some 478 boards.
o1die2
Postby evasive » Wed Sep 23, 2009 8:10 am
you want something that has 800Mhz FSB though to run this on full speed.
Specs:
http://processorfinder.intel.com/detail ... Spec=SL6WK
Postby bdub » Wed Sep 23, 2009 1:39 pm
there's one soc478 left at newegg, and it is a mATX...
http://www.newegg.com/Product/Product.a ... 6813138079
not totally sure if it runs northwoods... says it runs prescott.
does ddr2 and pci-e, which is a plus.
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
bdub
Postby evasive » Wed Sep 23, 2009 9:03 pm
It runs 800MHz FSB CPUs so should work. You could ask newegg beforehand though.
Postby AmEv » Thu Sep 24, 2009 5:14 pm
Now, the power supply.
What would you recommend for this board?
And video card?
*Just as a side question, is there really 2 different kinds of s478s, or would it be called something else? Just wondering, because this is similar to what I saw:
P4
Celeron, the one I was trying to upgrade:
**This is looking at the processor
AmEv
Postby fussnfeathers » Thu Sep 24, 2009 5:37 pm
Nope, only one socket 478. Different chipsets and mobo configurations supported different processor revisions, and a good majority supported all Celeron/P4's up to a point. Obviously, you couldn't drop an 800mhz FSB processor into a board rated for 533 (occasionally you could, it would just clock the processor back by 50%).
Faster than the speed of snot
fussnfeathers
Postby AmEv » Fri Sep 25, 2009 1:24 pm
As for video card and power supply...
What would you all recommend for this board?
AmEv
Return to Recommendations
Users browsing this forum: trendictionbot [Bot] and 0 guests
