Convertingt iMac Shell to PC (has it been done before?)
Postby GillianTan » Mon Dec 09, 2002 4:07 am
I read an article a while back on someone who put a PC into a G4 shell, but thats a bit bigger than an iMac :lol:
My NEW 3dMark score http://service.madonion.com/compare?2k1=4955820
Chaos reigns within. Reflect, repent, and reboot. Order shall return...
GillianTan
Postby charlene » Fri Dec 27, 2002 10:34 pm
I thought a G4 was an iMac :? :? :?
charlene
Postby mik8531 » Fri Jan 10, 2003 2:05 am
We had an IMac in the shop a month or two ago. It was really great; at some point in time it ended up being upside down on the workbench and it looked like some small four-legged, cycloptic animal had died on the bench. I had to fight the urge to get the masking tape and put a big "X" over the monitor. Regardless, you probably could find a few scrapped shells and use them to mess around with placement and such. I mean, you basically need to find a mobo that has what you need on it that will fit the dimensions given. It probably won't be much of a PC but it could work.
Things are more like they are now than they ever were before.
mik8531
Postby Wookie8662 » Fri Jan 10, 2003 3:07 am
Wookie8662
Postby effika » Fri Jan 10, 2003 5:10 am
Toaster PC
If somebody can fit it into a toaster, it can be fit into an iMac.
The powersupply and the monitor are the biggest problems that I forsee in the project.
effika
mother board u should use
Postby Jimmithy » Fri Feb 07, 2003 1:13 pm
use the via epia mini itx board
its probably the smalest mobo on the market.
on board video lan audio tv and s-video out
takes sdram 133
no flopy controler 8)
2 ide 100 ata
1 pci slot
cheap and has processor built in
mhz models range from 533-1000 the 533 model has a fanless heat sink so it is silent.
good cheap board :D
hop on the Ranvenswood
Jimmithy
Postby AmEv » Mon Oct 12, 2009 3:47 pm
effika wrote:Toaster PC
OK. I know this post is REALLY old.
But that sure is one way to burn a CD/DVD!
:toothy10:
AmEv
Postby AmEv » Mon Oct 19, 2009 6:18 am
Well, essentially this is what I am doing.
http://www.motherboards.org/forums/viewtopic.php?t=113426
AmEv
Previous
Return to System Modification
