It is currently Fri Nov 16, 2018 10:15 am
Post new topic Reply to topic  [ 18 posts ]  Go to page 1, 2  Next
PostPosted: Sun Nov 17, 2002 8:30 pm
I read a really good artical on how someone redesigned an Apple G4 system case to house a PC. Now I know the G4 case is way bigger than the space inside an iMac ....... BUT..... I would like to use the "innards" (crt and PS ) and the "Shell" of the iMac to make a PC :twisted: .
I am sure that I read that someone has done that mod before... But I can not find any data on it.
((Yes I did a search on google with over 1000 pages looked at....)
1) If anyone knows where a site that has done the mod is please either post or reply (e-mail)
2) Ideas for a mainboard with a VERY small foot print. (Space in the shell is VERY limited, (shape of shell).... if the MB uses header pins that would be even better as they are easier to route. ((Read BURN and CHOP the case to fit :D :D ))
Thanks to all in advance (will thank later also)... I have been reading this forum for sometime and have found the READ always worth "free time" (little that is available) WELL SPENT!
 Post subject: .....
PostPosted: Tue Nov 26, 2002 11:44 am
Imacs suck balls.
PostPosted: Thu Nov 28, 2002 5:32 pm
agreed
 Post subject: damned right!
PostPosted: Fri Nov 29, 2002 8:33 am
Damned right!
PostPosted: Sat Nov 30, 2002 12:33 pm
MACS RULE... Shut your mouth(mine has NEVER crashed, wish i could say that for my PC... :LOL: ).
anyway, if you go to macworld.com you can get instuctions on how to upgade an iMac. There you can find the placement fo the drives, etc.
BUT, good luck b/c you wont be able to get any PCI or AGP cards (basically EVERYTHING has to be onboard.....
Soyo KT333 Dragon Ultra Platinum, AMD athlon XP 2100+, Geforce3 Ti500, Western Digital 40GB 7200 RPM, Lite-on 16x DVD, Lite-on 40x12x48 CD-RW, *NEW* 400 watt power supply, AND a ahanix Platinum Xp case... :)
 Post subject: HAHAHAHAHAHAHAHAHAHAHAHA
PostPosted: Sat Nov 30, 2002 12:35 pm
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA!
Oh.......you are serious.......
PostPosted: Sat Nov 30, 2002 12:36 pm
Quote:
He who laughs last, thinks slowest.
PostPosted: Sat Nov 30, 2002 12:40 pm
And you are not laughing. Give it time, it will sink in how wrong you really are. Then you will laugh.
PostPosted: Sat Dec 07, 2002 12:03 pm
That's going to be one expensive mod. And why the would you want a PC in an iMac shell anyways - it's not like they look good or anything! This is just wrong in so many ways.
 Post subject: Why NOT???
PostPosted: Sun Dec 08, 2002 4:42 pm
Hmmmmm Lets see BECAUSE I WANT TO!
Do I really need any other reason???
Ok... For the challenge and because I can (if I can find a small enough MB/ setup)
THATS WHY...
Just curious why do you breath??? Because you want to and can......
(granted breathing is required
at least for mamalian life forms..... :lol:
