Logitech MX518 Gaming Mouse Mod Custom Paint
Postby Mnpctech.com » Sun Jul 05, 2009 4:44 am
Heres the steps taken to dismantle the Logitech MX518 Gaming Mouse. We're painting it with a Carbon Fiber effect
You will find 3, marked cross patterns for screw locations, using blade
Once opened, these 6 screws must be removed. 3 fasten in the switch for the right hand buttons
After removing right side button switch, 3 more screws are located beneath and must be removed
Before you can remove the MX518 mouse cover, you may have to push up the left/right mouse buttons up to clear the mouse body.
Then, gently, pull the cover off towards the rear of the mouse.
Apply masking alongside the MX518 Logitech emblem before prying off emblem with small flat head screwdriver.
To fill in the emblem hole, I'm using Evercoat, Metalworks, Polyester Glazing Putty with Blue Cream Hardener (not pictured)
Filling emblem hole of MX518. After mixing 1/4" size drop of Evercoat with dab of Blue Cream Hardener (not pictured)
If you apply too much filler, use paper towel to wipe off excess filler.
Allow filler to cure for 60 mins before sanding w/ 400 grit sandpaper
BEFORE PAINTING: USE THE PROPER SAFETY PRECAUTIONS
1. Wear Filtered Respirator Mask, Approved For Applying Automotive Aerosols
2. Work in Well Ventilated Area
5 coats of Rustoleum Sandable Primer (or until surface is filled)... allow to cure for at least 2 hours
Scuff the final coat sandable primer with 400 grit sandpaper before applying base color coat
The base color coat will be ISUZU factory color "Pewter" by PPG
PPG Automotive paint applied with HVLP spray gun
Gloss Black painted applied over rubber mesh (tool box liner) creates carbon fiber weave pattern
Light coats of Gloss Black will blend in the weave pattern
Polyurethane clearcoat applied for maximum durability and shine
Mnpctech.com
Postby james45 » Fri Jun 01, 2012 1:18 am
Wow! I never thought of having my computer mouse be personalized. Nice done dude! Let me do it for myself also.
james45
Postby Mnpctech.com » Tue Jul 31, 2012 5:47 pm
Glad you liked it!
Mnpctech.com
Postby Aries86 » Mon Apr 29, 2013 10:00 pm
Awesome! Thanks for that! Useful and competent to in this nation.., It is up in quality as well.
Aries86
Aries86
Return to System Modification
Users browsing this forum: BLEXBot [Bot] and 0 guests
