Project Panzerbox: A Tribute to Wolfenstein
Postby AmEv » Mon Oct 26, 2009 4:03 pm
Good, very good.
I don't know if you intended it or not, but the PSU fan behind the "gears" seems to give it a Swastika look.
*In a good way :roll: :lol: :wink:
AmEv
Postby Mnpctech.com » Sat Oct 31, 2009 3:51 am
I didn't even notice that! Thanks for commenting
Our HD arrived, Western Digital Caviar Blue WD2500AAJS 250GB 7200 RPM 8MB Cache SATA 3.0Gb
$44.99 shipped!
http://www.newegg.com/Product/Product.a ... 6822136113
Mnpctech.com
Postby Mnpctech.com » Mon Nov 02, 2009 6:22 pm
Nate started the system install Sunday afternoon. The Thermalright Ultra 120 Extreme Revision A HSF clears the chassis.
250mm fan draws out the warm air from the Ultra 120 Extreme Revision A
Thermalright has since updated the mounting bracket to turn the HSF 90 degrees and avoid blocking DDR in first two slots
We'll be using these new PC Cable management clamps
http://www.mnpctech.com/CableClamp.html
Nate from CustomPCMax.com
Mnpctech.com
Postby Mnpctech.com » Tue Nov 03, 2009 4:30 am
Nate and I agreed top of Heat sink fins looks naked, it needs something... More on that later :thumb:
Mnpctech.com
Postby Mnpctech.com » Wed Nov 04, 2009 4:40 pm
We'll be painting the 5.1 surround sound headset we received from Psyko Audio with matching camo
Mnpctech.com
Postby THRASHER2 » Wed Nov 04, 2009 8:13 pm
Those are some KOOL head-phones :)
THRASHER2
Postby Mnpctech.com » Fri Nov 06, 2009 10:36 am
The dissection of a Psyko Audio Headset, before prepped for Camo paint
The padded ear cup pads can be popped off with their pivoting bases (grab around the top of the plastic ring and pull it out).
4 screws total, 2 on each side fasten on outter Silver trim piece
4, screw locations to be removed.
The clear cup cover is easily removed, once the outter trim piece is removed.
The clear cover pops off (push a small flat head screw driver into the gaps to pry off).
The pads are peeled off. I used a small flat head screw driver to pry up the edge first.
You can peel off the top 5 pads to reveal 5 screws holding on the top Silver cover.
5x 30mm diam. 32 ohm. speakers project sound into your skull
Mnpctech.com
Postby Mnpctech.com » Sat Nov 07, 2009 5:12 am
I agree! After the pads are removed, the headset is re-assembled before being masked off before camo paint job. It's easier to apply the camo stencils when it's all assembled without the pads
Mnpctech.com
Postby Mnpctech.com » Sat Nov 07, 2009 5:21 pm
For tidying up the PSU cables, I'm using the small size PC Cable Clamps, they hold approximately 1" bundle
PC Cable Clamp Link
Mnpctech.com
Postby Mnpctech.com » Thu Nov 12, 2009 1:54 pm
Brad sent me progress on the Camo paint on the Pysko Audio head phones. These will look awesome!
Headset
Amp
Mic
Mnpctech.com
PreviousNext
Return to System Modification
Users browsing this forum: Istellabot [Crawler] and 1 guest
