Mnpctech.com Black Belt
Posted: Wed May 20, 2009 1:46 pm Post subject: Guide to Tools For Case Modding |
Another Helpful Guide by Mnpctech.com
These are the most common Tool I use for Case Modding.
THINK SAFETY FIRST!
Safety Glasses
Respirator Mask with canister filters
Use when sanding, painting or using any hazardous chemicals
Rotary Cutting Tool
The most versatile tool for case modding. You can cut plastics, metals, grind and polish. Dremel brand is most popular. Black & Decker and Craftsman versions are also popular.
Dremel Techniques For Case Modding, Part 1
Dremel Techniques For Case Modding, Part 2
I hear a lot of complaints about cutting discs breaking when cutting metal. You need to use aluminum reinforced discs like these Reinforced Dremel Cutting Discs
Reinforced 1.5" Dremel Cutting Discs. Available here
Cordless Power drill
Minimum volts recommened 14.4V) with bit sizes 1/16 through ½ for cutting various mounting holes and
operating hole saw attachments. DeWalt brand power tools.
Hole saw attachments for Drill
For cutting fan holes in acrylic and metal.
80mm = 3” hole saw
92mm = 3.5” hole saw
120mm = 4.5” hole saw
Video Guide To Using Hole Saw Attachments For PC Modding
[b]Greenlee Knock out Punches
Greenlee part # 730EBB-120 Last time I inquired, they were around $450 in the states + Large 3/4" socket wrench, and 2" socket. I wouldn't use anything less than 19" long socket wrench. Estimated purchase price of $550 new.
Threaded shaft of Knock-out punch
Knock-out punch blade
Ready to cut hole.
You need leverage. Using 19" Socket wrench to draw in knock-out punch balde
Clean Cut
Video with Bill Owen using Greenlee Knock Out Punch
[youtube]NX3YbhRrOvM[/youtube]
Roper Whitney No. 5 Jr Hand Punch kit available here
Hand punch (estimate $60 new)
(for cutting fan mounting holes or enlarging existing fan mounting holes for rubber silencing grommets)
Hand Punch makes clean fan screw holes. No deburring.
Jigsaw
Used for cutting panels and acrylic sheets. (minimum 18 teeth metal cutting blade) Black & Decker brand Jigsaws available here
Hand files
Deburring jagged edges on both plastic and metal.
Mouse Sander
Sanding body filler. Prep case panels for paint.
12” and 24" Combination Square Rulers
Aligning windows, fan holes etc
Scotch Clear double sided adhesive tape #4010
Acoustical Sound Proofing Sheets for your PC
colored sheets of cast acrylic for window mods
http://www.mnpctech.com/colored_acrylic_sheet_casemod_windows1.html
This is the Honeycomb Modders Meshwe used.
PC Cable management clamps
http://www.mnpctech.com/CableClamp.html
Pop Rivet Gun
Most chassis accept 1/8” size rivets.
Metal Nibbler
Cutting case panels
Metal Tin snips
Cutting Modders Mesh & Sheet metal
Solder Gun or Pencil
Heat Gun
Heat shrink tubing, bending acrylics/plastics
More Tools, but no photos yet..
Phillips Screw drivers(variety of sizes)
Wire Stripper & Cutter
Butane Torch(for use with heat shrink tubing)
Tape Measure
Bench Vise
Last edited by Mnpctech.com on Sat Dec 05, 2009 4:37 am; edited 2 times in total |
Posted: Fri Nov 06, 2009 1:05 pm Post subject: |
| I need to add a Belt Sander to my Power Tool Arsenal |
fussnfeathers Mobo-fu Master
Posted: Sat Mar 27, 2010 6:00 pm Post subject: |
Those are good. Practically indestructible, I've got one similar that's 30+ years old. _________________ Mine go to 11 |
Posted: Fri Apr 09, 2010 7:39 am Post subject: |
| fussnfeathers wrote: | | Those are good. Practically indestructible, I've got one similar that's 30+ years old. |
Good to hear! and no terribly loud either.. |
Posted: Fri Jun 04, 2010 7:30 pm Post subject: |
I'm getting a lot people asking off list, Asking which size to buy for 140mm size cooling fans.
You can use a 5.5" size Hole Saw Attachment. (140mm = 5.51181")
Amazon has good selections for 5.5" "Bi-Metal" Hole Saw attachment for your Power drill, HERE
Other Hole saw attachment sizes
80mm = 3” hole saw
120mm = 4.5” hole saw |
Posted: Mon Mar 28, 2011 1:13 pm Post subject: |
“Mushkin Enhanced” PC Mod stacks two Cooler Master Wave Masters! ....See More photos
