GodSquirrel Guest
Posted: Tue Jul 29, 2008 8:24 pm Post subject: XFX GeForce 8200 Review |
| Read about it here. |
willyab Pilgrim
Posted: Fri Aug 22, 2008 6:27 pm Post subject: |
Hey godsquirrel, I just got a reply from XFX asking about using a x4 9950 cpu on this board. their reply was that "The X4 9950 is not supported by the 8200 motherboard. You will need to stick to 9w watt or lower socket AM2/AM2+ processors."
I noticed that you used a 9850 processor on you test. Did you have any problems with it getting hot? Any thoughts as to their vague reply?
Thanks! |
ben2207 Green Belt
Posted: Fri Aug 22, 2008 6:59 pm Post subject: |
| Hi as the author of that review I should indicate that I was able to use the several 8200s I've tested with the 9850 without problems including XFX and EVGA. No issues as to heat though the board did heat up to 49C. Onething to note, that other 8200 boards including Asrock (um did I dare say that name?) support the 9950. Note, however, that I cannot guarantee it'll work as I've had a few 780G boards not work with the CPU. |
willyab Pilgrim
Posted: Sat Aug 23, 2008 2:39 am Post subject: |
Thanks for the reply!!
So for my board specifically, XFX Geforce 8200 mobo, you feel that the 9850 will work w/o any issues. I'm running a X3 8450 right now and want to bump it up to a quad. I was just wanting to get the highest rated one I can with that board. Is there a cpu cooler that you recommend with the 9850? |
gothboy8149 Pilgrim
Posted: Sun Nov 01, 2009 11:34 am Post subject: GeForce 8200 mGPU AMD AM2 Motherboard MIA78S8209 |
hi, i read your test set-up pages and you state that the motherboard can handle 32gb, when i got mine it said that max memory was 8gb. Can my motherboard take up to 32gb as yours says? Any help would be grateful
MAtt |
