find my old posts
find my old posts
Postby leasoncre » Tue Jan 29, 2008 3:41 pm
I whould like to be able view all my posts that i have ever posted. (old, new, etc; find within range of dates, fourms, and other options) (I tend to ferget where i put them all) maybe put this in "My profile" tab or something
does this already exist? if so it's not user-friendly to find eisily.
And the current search engine really does suck, there is no revelencey.
leasoncre
Postby greytrains » Tue Jan 29, 2008 3:53 pm
The current search engine can search by author. There is also a link on the forum index page called "View your posts." This will show every post you have ever made
greytrains
Postby leasoncre » Tue Jan 29, 2008 4:36 pm
thank you, i guess it was evading my eye.
leasoncre
Postby hunter1801 » Tue Jan 29, 2008 9:50 pm
You can also click on the profile button under each post you make and click "Find all posts by leasoncre".
hunter1801
