i need user's manual PLEASE hELP =(
Goto page 1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
Post new topic   Reply to topic    The Mother Board Forum Index -> Motherboard Identification Forum
lilthug118
PostPosted: Thu Dec 13, 2007 9:01 pm    Post subject: i need user's manual PLEASE hELP =( Reply with quote
hey i need a user's manual for Asus P4SD i865PE Socket 478 mATX MB w/VID SND & LAN and the link for the motherboard is right here http://www.geeks.com/details.asp?invtid=ASUS-P4SD-WB-R
please help
PostPosted: Fri Dec 14, 2007 7:59 am    Post subject: Reply with quote
Welcome to Motherboards.org!
Home site for Asus: http://www.asus.com/
Here is the page link for driver/manual for the various mobos. Your specific model wasn't listed. Input your criteria and choose one that is closest. Google didn't offer any links for manuals to that model.
PostPosted: Fri Dec 14, 2007 11:02 am    Post subject: Reply with quote
Quote:
Additional Information:
* Notes:
* Model: P4SD
* Motherboard is OEM for HP
* Motherboard only: I/O shield, cables, screws, etc. are not included
so find out which P4SD or P4SD-LA variant it is and we'll try and locate all info and drivers for it...
lilthug118
PostPosted: Fri Dec 14, 2007 5:41 pm    Post subject: Reply with quote
how do i find that out
PostPosted: Sat Dec 15, 2007 6:40 am    Post subject: Reply with quote
Look over the motherboard carefully, even on the side of device slots. There should be some labels or print on the surface, possibly a bar-code label on a port shield.
PostPosted: Sun Dec 16, 2007 10:18 am    Post subject: Reply with quote
If it's simple P4SD and not P4SD-LA, then it's the board used in the Evo D330/D530 series. I might be able to find info on that.
lilthug118
PostPosted: Sun Dec 16, 2007 1:56 pm    Post subject: Reply with quote
i believe its a simple P4SD
PostPosted: Tue Dec 18, 2007 11:19 pm    Post subject: Reply with quote
Here is the tech info:
http://www.ctechinfo.org/boards/asus/p4sd.html
This might be how the front panel header should be connected:
18 17
16 15
14 13
12 11
10 09
08 07
06 05
04 03
02 01
Pin 14 is empty - no pin
Pins 1 and 3 - HDD LED
Pins 5 and 7 - Reset SW
Pins 2 and 4 - PWR LED
Pins 6 and 8 - PWR SW
PINs 17 and 18 are jumpered together
or it is:
pin 1 is blank
pin 2 black from power switch
pin 3 green from power switch
pin 4 missing, blocked on front panel connector
pin 5 yellow for harddisk LED
pin 6 black for harddisk LED
pin 7 red for power LED
pin 8 black for power LED
depending on what variant they fitted on this board, these are two common compaq front panel layouts, as you can see on the page, we have no idea which one is fitted on the P4SD yet. Let us know please.
dontbuyemachines
PostPosted: Sun Dec 23, 2007 6:08 pm    Post subject: Reply with quote
I also bought this mobo last week to replace an emachines mobo from Intel.
Has anyone confirmed the front panel jumper pin layout? I don't want to fry
the new mobo because the power pins went to the wrong place.
Thanks.
Copper
PostPosted: Mon Dec 24, 2007 4:03 am    Post subject: Reply with quote
Thanks.
no harm should come to your motherboard if the wires are inadvertantly put in the wrong place
Post new topic   Reply to topic    The Mother Board Forum Index -> Motherboard Identification Forum All times are GMT - 8 Hours
Page 1 of 10
