kool case idea.
kool case idea.
Postby aussiejunior » Thu Nov 08, 2007 7:13 pm
Howdy all... I'm kinda new to the modding scene but being as I'm an avid gamer and love to overclock everything I can in me computer i was wondering on using different things for cases. I've been given an old bar fridge and was wondering if I could use that or would the condensation build up to much?
core i7 920@4.0ghz
asrock x58 extreme 3
Creative x-fi xtreme gamer
aussiejunior
Postby ajrox » Sun Nov 11, 2007 12:54 pm
it would work...probably....
just get an old atx case and cut out the mobo tray and drive housing so you can mount the components properly.
be aware that it will eat loads of power trying to cool the components. you might get some 2 liter bottles and freeze them to act as cool sinks...
you should most certainly try it with an old junker first...
however...the condensation will only appear if the inside fridge temp and the components temps are greater than 10 degrees or so...
EVGA 790i tri SLI
intel core2 quad 9550
6gb G.SKILL DDR3 16000
3X EVGA 8800gts video cards
water cooled fo sho
the rest when i get paid
ajrox
Postby aussiejunior » Sun Nov 11, 2007 6:49 pm
kool i'll definatley have to try it out
core i7 920@4.0ghz
aussiejunior
Postby Sabrewings » Sun Nov 11, 2007 8:43 pm
A fridge is designed to cool certain items and then maintain that temperature. It isn't designed to fight an internal heat source. I doubt it would be able to cool very much.
Sabrewings
Postby aussiejunior » Wed Nov 14, 2007 6:49 pm
damn.. well at least it was only an idea still... lol.. One of the coolest ideas I've seen is I have a mate who has built his computer in an old microwave and he says everything remains cool enuf in that lol
core i7 920@4.0ghz
aussiejunior
Postby kylepaddock » Sat Jun 28, 2008 7:30 pm
you could add a de-humidifyer(sp) to fix the condensation
Gateway MT6707 Notebook
Intel Pentium Dual Core T2060 1.6 GHz
Memory 2048 MB 533MHz DDR2 SDRAM
Intel Graphics Media Accelerator 950
224 MB shared video memory
High definition audio 2 channel
160 GB HD
8X Multi-format dual layer optical drive
802.11g wireless LAN
4 USB 2.0 ports
One VGA port
One S-Video
One IEEE 1394
One PCMCIA Slot
If you have done a transaction with me, please fill out my heatware. http://www.heatware.com/eval.php?id=64039
kylepaddock
Postby thomas_w_bowman » Wed Jul 15, 2009 8:49 am
OK - this is an ancient post - but this like looks like how to severely coll a PS (Note heavy wattage requirements):
http://www.frozencpu.com/cat/l2/g30/c10 ... DQodtXG__A
Join Folding team #: 33258
thomas_w_bowman
Return to System Modification
