evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36383 Location: Netherlands, Breda
Posted: Mon Apr 23, 2012 11:27 am Post subject: |
| bdub wrote: |
obsessive-compulsive disorder... in this case he sees the mistake he made, which causes him uneasy, distressing, intrusive thoughts about fixing it, but he can't. in higher order OCD patients, constant reminding of this failure could cause mental collapse. | you think comma's would help?
bad, bad, capacitors? _________________ We hate rut, but we fear change.
bdub Black Belt 3rd Degree
Joined: 19 Feb 2003 Posts: 3328 Location: Washington D.C.
Posted: Mon Apr 23, 2012 11:38 am Post subject: |
| evasive wrote: | | bdub wrote: |
bad, bad, capacitors? |
that would prolly make it even worse. _________________ my main rig...
asrock 970 extreme3
AMD athlonII X3 440
zalman cpns5x performa hs/fan
antec neo he 650r
kingston hyperx 3k ssd 120GB
seagate 500GB HDD 32M cache
seagate 750GB HDD 32M cache
hitachi 1TB HDD 32M cache
lg wh14ns40 bd burner
cordsally Pilgrim
Posted: Wed May 30, 2012 7:16 am Post subject: |
Has you got the solution of this or you just drop this matter behind......  |
Karlsweldt Enlightened Master
Posted: Wed May 30, 2012 8:49 am Post subject: |
| cordsally wrote: | Has you got the solution of this or you just drop this matter behind......  |
The only solution to bad capacitors is to replace them.. with better-quality units. Capacitors are made in many forms and types and voltage/temperature ranges.. to suit the need. Heat is the major enemy of capacitors. The "dry" type (ceramic) seldom have problems.. unless given a high jolt of voltage. The common electrolytic type will allow gaseous discharge of its electrolyte liquids at high temperatures.. causing fatal faults after a long use time. Also, a formula for the electrolyte must be "friendly" to the materials used to make them.. otherwise corrosion causes rapid internal failure.
Whenever replacing faulty capacitors, use only the same Farad rating. The voltage can be the same, never lower.. but higher is acceptable. The temperature range is to be the same or higher also.. never lower.
With data-transfer or timing circuits involving capacitors, the same value is required.. or performance will be severely affected. For capacitors used in DC power filter circuits, a higher Farad value might be acceptable.
To compile a database of problematic types can take a long time.. unless someone is tasked with that ominous chore by itself. Not a 'career' I would want!!!  _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
Posted: Thu May 31, 2012 1:37 am Post subject: |
| Karlsweldt wrote: |
To compile a database of problematic types can take a long time.. unless someone is tasked with that ominous chore by itself. Not a 'career' I would want!!!  |
Which is what these people did:
http://capacitor.web.fc2.com/
Just a matter of how good your Chinese is or how well you are in understanding the Google translate dialect of English...  _________________ We hate rut, but we fear change.
profofpcs Black Belt 5th Degree
Joined: 08 Jul 2002 Posts: 9890 Location: gold country
Posted: Wed Sep 19, 2012 7:39 pm Post subject: |
you could add these boards from my personal experience:
Abit VA-10
Shuttle AN35N-Ultra
Albatron KX400-8X
even just sitting there caps bulged and leaked. 3 of the computers i used to Fold with. _________________
anger is just danger without the "d" |
Posted: Thu Sep 20, 2012 5:19 am Post subject: |
Likely they were the victims of the "bad caps" formula.. and time does have its effects with corrosion internally. When you note the exterior signs, when it is then critical! I, too, have had some "new" motherboards develop bad caps.. while in a suitable environment, in sealed pouches!! _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
Posted: Sat Jan 12, 2013 10:10 am Post subject: |
New addition to the "bad caps" gang! A friend asked me to look at his old system, with an ECS P4VXAD mobo.. locking up and rebooting. Guess what.. one bad cap behind the CPU socket! But only one of about nine showed a domed top. It was branded "Elite", 3300 mfd. at 6.3 volts.. 105°C rated.
Only running a 2.8 Northwood at 400 FSB, and is used only for Web browsing and minor needs. Will have to do checks every few months to see if more go bad. _________________ F@H.. to solve mankind's maladies.. in our lifetimes! |
Posted: Tue Jan 15, 2013 1:17 am Post subject: |
Elite, made by Chinsan. Made in Thailand, headquarters in China... _________________ We hate rut, but we fear change.
