Using 2 modems on one line
chieftex
Post by chieftex »
Is this possible? Say two computers in different parts of the house, each with its own adsl modem, plugged into the same line. Can they both be used at the same time?
Intel E4500 @ 2.2ghz (stock)
Asrock P45DE motherboard
2x 2GB Ballistix DDR2-800
Xfx HD 4890
2x hdds
2x odds
Antec NeoHE 500w PSU
filecore
Post by filecore »
Short answer: No.
Medium answer: Why?
Long answer: Although generally you can't, if you are purchasing two IPs from your ISP then you should be able to - although if you were doing that, I rather suspect you wouldn't be asking this question anyway.
Again, why are you asking this? It would be much cheaper and easier to simply (buy a router and) run a CAT5 cable to the computer in the other room; if this is impossible, you will need to go down the wireless route, but wireless equipment isn't particularly expensive anymore. If you're not doing any intra-network file transfers, you could even purchase wireless-B equipment, as this will still be faster than your internet connection.
chieftex
Post by chieftex »
why?
well
I have to wireless B routers, and two Wireless B ethernet bridges. Now, I want to connect one of the computers wired, to get the fastest connection, but I dont want the others to suffer from poor wireless speeds.
However, you may have hit the nail on the head - its doubtful that my internet connection is anywhere near the speed of my wireless connection...
Xfx HD 4890
2x hdds
2x odds
filecore
Post by filecore »
Two options: internet -> router A. Router A wired -> computer 1, wireless to computers 2-4 + Router B. Router B wireless and/or wired to whoever. Basically, use your second router as a switch.
Second option: QoS. It stands for Quality of Service and if it's on your router (don't know the model or brand), then you can specify that computer 1 can use a maximum of 100% of the unused bandwidth, while computer 2 can consume only 75% or 30% or whatever. That way, one always has priority over the others and so on down the heirarchy. Search on Google for QoS and your router model, and you'll probably find lots of stuff.
chieftex
Post by chieftex »
so two routers will connect to two computers wired, BUT the whole thing is limited by the speed/connection quality between the two wireless routers right? Wouldnt that defeat the object?
Xfx HD 4890
2x hdds
2x odds
filecore
Post by filecore »
Internally you can connect wired machines (probably 4, please tell me the model of your devices!) to each of them, as well as plenty of wireless clients. The speed is limited to the maximum speed of the units - 10Mbps wireless, 100Mbps wired. However, that's only for transferring between computers - assuming you have, let's say, 1Mbps internet (which is what I have), then it's slower than any of your internal traffic and therefore for internet speeds, it doesn't matter if it's wired or wireless.
Post by Hardware Junkie »
In order to combine internet connections to achieve an overall faster speed you would need a special router aswell.
http://www.hawkingtech.com/products/pro ... &ProdID=20
The term is called Load Balancing
[i]"Imagination is the only weapon in the war against reality." -Jules de Gautier[/i]
[url=http://www.windowfarms.org/][img]http://homegrown.org/blog/wp-content/uploads/2009/08/window-farm-iconic3-150x150.jpg[/img][/url]
filecore
Post by filecore »
Very interesting - however, I was curious about the price, and when I clicked on their shop thing, I got a nice "Item not found!" message. Oh well.
EDIT: Having said that, they're having a close-out sale on their dual WAN 4-port wireless router, down from 180 to only 80 USD... not bad. I'd consider it if I could afford two internet connections ;-)
~PJ~
Post by ~PJ~ »
How weird. I came on to ask the self-same question - although in my case it was only going to be temporary - trying to set up new adsl router on one computer whilst client is still using old modem on his laptop.
So I assume I can't so that, then? Why not??
[img]http://www.motherboards.org/sig/sig6/33258/Purplejulia77/sig.jpg[/img]
Peace for its people,
Love in our lives,
Delight in the good,
Forgiveness for past wrongs,
And from now on a new start.
~PJ~ wrote:How weird. I came on to ask the self-same question - although in my case it was only going to be temporary - trying to set up new adsl router on one computer whilst client is still using old modem on his laptop.
In order to use two internet connections at the same time you need something to load balance between them. Otherwise, your o/s will just choose one.
Post Reply
