| What do you think of the new forum? |
| It sucks |
3% |
[ 3 ] |
| I love it |
91% |
[ 83 ] |
| The old one was better |
5% |
[ 5 ] |
| Total Votes : 91 |
guevi2 Guest
Posted: Fri May 10, 2002 12:35 pm Post subject: Password Lost Vic |
the problem i have is that the email address i have written in my profile as Vic is no longer working. and i cannot retrieve my pastword for my identity as vic. you webmaster will have to retrieve it and email it to me at my current email address under my identity of guevi2. i will stop using this identity.
thanks
[[/img] |
Black Orchid Green Belt
Posted: Fri May 10, 2002 3:00 pm Post subject: |
| This is much better. I'm glad you made the change. |
Pechorin Brown Belt
Posted: Fri May 10, 2002 3:40 pm Post subject: I agree |
After poking around a bit, I give it a thumbs up.
By the way, why did I loose a star (or chip) in the conversion? Did the "rate member" function change in the conversion or did I just piss someone off?
Anyhow, kudos to MoboCop for the upgrade!!!  _________________ “Education is the most powerful weapon which you can use to change the world"
--Nelsen Mandela |
MoboCop Drunken Master
Posted: Fri May 10, 2002 3:47 pm Post subject: |
I have tweaked the ranking process a bit and I may a bit more.
Basically I have raised the bar a bit on the ranks.
Please rest assured that it was not an attempt to devalue anyone but merely to add more value to each level attained. _________________ Not everything that can be counted counts, and not everything that counts can be counted - Albert Einstien |
Hardware Junkie Mobo-fu Master
Joined: 25 Jan 2001 Posts: 19351 Location: 00000h - 0000Fh
Posted: Fri May 10, 2002 3:55 pm Post subject: Ranking |
How are the stars/chips obtained? I see no area to rank people? Unless its based on posts or some other factor. _________________ "Imagination is the only weapon in the war against reality." -Jules de Gautier
Doc Overclock Lord Of The Realm
Joined: 25 May 2000 Posts: 3328 Location: Star Fleet Academy
Posted: Fri May 10, 2002 5:34 pm Post subject: |
That is what it is based on Nic!!!
 _________________ Doc Overclock - Adventures In Electricity |
Tolemac Mobo-fu Master
Joined: 12 Sep 2000 Posts: 14276 Location: L-1 Bridge
Posted: Fri May 10, 2002 6:55 pm Post subject: Hmm |
Yes I was also amused by this but obviously not as much... _________________ "Imagination is the only weapon in the war against reality." -Jules de Gautier
bonz_dragon Brown Belt
Posted: Sat May 11, 2002 9:49 pm Post subject: |
Very Interesting!!!
Time will tell, I've seen other BBS that changed format and worked well while others fell apart. This one still has a great resource of people!
Bonz_dragon  |
evasive Mobo-fu Master
Joined: 06 May 2001 Posts: 36385 Location: Netherlands, Breda
Posted: Sun May 12, 2002 2:51 am Post subject: |
This BBS software has already proven itself at wimsbios and sysopt. It should be faster than UltimateBB. _________________ We hate rut, but we fear change.
