It is currently Fri Oct 19, 2018 11:59 am
 Post subject: AMD Cooling Help
PostPosted: Thu Jun 21, 2007 11:26 pm
Soooo, here lately I've been worried about my CPU temp. It's... between 120 - 135 average.. I've seen it peak at 145, when the emergency shutdown kicks in at about 156.
I'm running and AMD Athlon XP 3000+ I believe. >.> I've got a nice sized fan in it, have Air flowing in from the back above my CPU, and out of the side...
o_O I know it's not safe for it to run that hot, but I'm low on cash right now, so does anyone have any tips on how I can lower my temperature or will it be fine for now? T__T I'm so afraid.
PostPosted: Fri Jun 22, 2007 8:48 am
what is the ambient temp in the room the pc is in?
If its pretty hot turn up the ac if thats possible for you to do, the lower the room temp the lower your pc temps will be
Fans only move around air they dont really cool it.
PostPosted: Sat Jul 07, 2007 2:16 am
Is the heatsink as toasty hot as the CPU? If not then your problem could be due to poor thermal interface due to heatsink not being seated on the CPU properly or poor/dried out paste. Taking off the heatsink, giving everything a good clean and reseating with decent paste could solve the problem.
PostPosted: Sat Jul 07, 2007 5:20 am
remove side panel, replace with a box fan :wink:
 Post subject: Re: AMD Cooling Help
PostPosted: Tue Aug 07, 2007 3:48 pm
I feel that every fan on the back-side of the case should exhaust air out of the case.
If you've got a fan (for example, a fan located just below the Power Supply) pushing air into the case, it's probably going to be grabbing the hot air which the Power Supply recently vented out of the case. This would not help to cool the system.
To solve the problem in my example, ensure all fans on the back of the case exhaust air out of the case. Ensure all fans (if any?) at the front of the case are sucking air into the case.
I've you've got a spare PCI slot, consider putting an exhaust fan in that location. Something like this would be good.
http://www.compusa.com/products/product_info.asp?pfp=BROWSE&N=200369&Ns=display%5Fprice%7C0&product_code=50063202
If you've got an empty 5.25" drive bay, you could drill a pattern of holes in the blank cover for the bay. This creates an intake grille for cool air to be sucked into the case. Or something like this would work.
http://www.compusa.com/products/product_info.asp?pfp=BROWSE&No=20&N=200369&Ns=display%5Fprice%7C0&product_code=288618
Since you're using side cooling duct(s), I suggest experimenting with them to determine whether it is better for them to suck cool air in or to exhaust hot air out.
In my experience, it hasn't been necessary to use intake fans at the front of a case (even if they're installed, I can disconnect their power and reduce my noise levels). As long as the Power Supply and rear exhaust fan(s) are working properly, there is enough air movement to cool a system.
Sincerely,
MrCraigCraig
PostPosted: Tue Aug 07, 2007 6:11 pm
If you can flip over the CPU fan to make it an exhaust fan (pulling heat away from the heatsink), try a duct mod.
You can also try a duct mod for an intake setup.
