It is currently Wed Dec 12, 2018 10:24 pm
PostPosted: Wed May 09, 2007 1:20 pm
I want to install the swiftech MCW60 water block on my 8800 GTS, But I have already got a pre-existing water cooling setup(the swiftech p180 water cooling case.)
Is there any specific way I need to purge the system of water so I can add extra tubing to put the vga waterblock in the loop?
Thanks,
Lavarock.
PostPosted: Sat Jun 16, 2007 4:08 am
I always just flushed my systems with running water for about 5 min, let it dry, do my work. Then put in distilled water with coolant solution.
