It is currently Fri Dec 14, 2018 10:54 pm
PostPosted: Wed Mar 07, 2007 4:38 pm
any one with experience watercooling the chipset on the EVGA 122-CK-NF68-AR
specs/pics
http://www.newegg.com/product/product.a ... 6813188009
a better pic
http://www.pcper.com/image.php?aid=320& ... rd_big.jpg
or have opinions on whether it can be done/ how hard it would be.
thanks all
PostPosted: Thu Mar 08, 2007 11:36 pm
you can't just remove the heatpipe coolers & plop some waterblocks on there?
 Post subject: clearance
PostPosted: Fri Mar 09, 2007 11:57 am
the sink on the SouthBridge is designed to allow cards like the GTX 8800 to fit & if you change the SB heatsink you've got clearance issues w/ the GTX
so i was hopin that som1 would have a recommendation as to the waterblock that might fit...
I know that cooling the SB isnt in a 'normal' W.C. setup but if you remove the NB heatink the cooling from the SB is going to be effected.
mabe i wasnt specific enough with this post. oh well. 1 way to find out for sure. Buy the stuff & give it a shot!
